Thread: is TBA neccessary after battery disconnect?
  1. is TBA neccessary after battery disconnect?
    Jul 2020
    Birmingham, England
    Hi all,
    I want to clean up my battery terminals so need to disconnect it. I had errors thrown up while driving so think it was a battery issue, all solved itself after leaving the car off for a few minutes.
    I read online that a battery disconnect resets the ECU and also requires a TBA.
    Can anyone confirm if this is necessary, or does it not matter?
    Is there a way to reset it without VCDS, some posts say to just put ignition on and floor the accelerator for like 10 seconds or something.
    it is a 2016 Polo 1.0 TSI.
    Thank you
    Ji
  2. Re: is TBA neccessary after battery disconnect?
    1840 Post(s)
    It should be done but isn’t always necessary.
  3. is TBA neccessary after battery disconnect?
    Jul 2020
    Birmingham, England
    Ok thanks crasher, guess I can risk it and hope all is well when I disconnect it, lol.
    How can I know if it's throttle cable or DBW, & more specifically which connection method ? (UDS, KWP-2000 / CAN or KW-1281?)
  4. Re: is TBA neccessary after battery disconnect?
    1840 Post(s)
    It is drive by wire, without VCDS that is all you need to know.
  5. Re: is TBA neccessary after battery disconnect?
    Jul 2020
    Birmingham, England
    I have access to VCDS at my dads house, so that should tell me, right?
  6. Re: is TBA neccessary after battery disconnect?
    1840 Post(s)
    It will have the function, Basic Settings 04, group 060, start, wait 30 seconds (whirring and clicking), exit basic settings and Engine 01, ignition off for 30 seconds, ignition on, wait 30 seconds (whirring and clicking) and start.
  1. Disconnect A5 tdi battery
    By GeoffM1 in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 02-03-2018, 02:53 PM
  2. Question Battery Disconnect
    By Stagecoach in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-07-2012, 01:55 PM
  3. Can I disconnect battery without any problems.
    By driver2008 in forum Golf MK4 - 1999 - 2004
    Last Post: 21-03-2010, 11:48 PM
  4. Question Disconnect battery problem
    By nige100 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-12-2009, 02:21 PM
  5. About to disconnect battery on 2003 C5 A6 1.9 TDI
    By paul b in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 09-03-2009, 08:03 PM
