Thread: Re-map/Service/Vag-com
  1. Re-map/Service/Vag-com
    Nov 2006
    A friend is asking what would happen if his Audi was re-mapped and then took it in for a ******* service. Would they plug into his ECU, notice it was re-mapped and then erase it and go back to the original map?!
    As a side note, would he be able to tell (apart from driving!) that his re-map had been erased? i.e. could he tell via vag-com that the ECU had been altered? Where in vag-com should he look at? This is all assuming he's had a flash re-map done via the OBD port.
    Cheers.
  2. Re: Re-map/Service/Vag-com
    Dec 2006
    The Delaer wont be able to see the re-map, all the updates are done without updating the orginal version numbers etc..
    in regards to if the dealer decides to update the firmeware, thats a question for Chipped UK to answer?
    Rick
  1. Does resetting service indicator set service regime to fixed?
    By golfgtdude in forum Golf MK5 - 2004 - 2009
    Last Post: 01-10-2007, 06:38 PM
  2. Mk4 v6 service
    By Ruthless99 in forum Golf MK4 - 1999 - 2004
    Last Post: 16-08-2007, 05:30 PM
  3. '07 A4 service
    By tomym396 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 24-05-2007, 06:36 AM
  4. Service now
    By phils2309 in forum Passat - Archive Topics
    Last Post: 01-12-2006, 03:05 AM
  5. A4 Air-Con Service
    By kitt247 in forum Audi A4 - Archive Topics
    Last Post: 28-07-2006, 05:00 PM
