Thread: Front suspension knock
Results 1 to 10 of 15
  1. Front suspension knock
    Dec 2013
    Liverpool
    10 Post(s)
    I have the dreaded knock from the front suspension, I have changed the suspension arms but unfortunately it has not fully cured the "knocking" any ideas what else could be causing this noise. starting to fall out of love with my A6.
    Wires to the plug that connects to the front fog light have broken right next to the plug, is the plug a replaceable part?
    2007 2.7 SE quattro saloon
  2. Re: Front suspension knock
    1840 Post(s)
    Did you use ALL new OE spec fasteners? Yes the plug is replace, it will have the (tiny) part number moulded in and there are repair wires to install and then solder to the originals.
  3. Re: Front suspension knock
    Dec 2013
    Liverpool
    10 Post(s)
    Hi Crasher, yes all new fixings used that arrived with the various arms.
    have put plug back so will try and find it on GOOGLE.
  4. Re: Front suspension knock
    Dec 2013
    Liverpool
    10 Post(s)
    Sorted the plug out, would tou happen to have the torque values?
  5. Re: Front suspension knock
    1840 Post(s)
    New nuts…?
  6. Re: Front suspension knock
    Dec 2013
    Liverpool
    10 Post(s)
    Yes all new fixings
  7. Re: Front suspension knock
    Sep 2020
    South Wales
    I’ve had a knock on my drivers side, accompanied with vibration.
    Vibration is now gone - turns out the two new balanced tyres weren’t actually ballanced! 🤣
    Bought a load of control arms, however the more I look into it - the less convinced my knock is control arms related, also bought new retaining springs for front brakes!
    Also found that the sub-frame bushes are prone to wear on these cars, which also can produce a knock along with vague handling.
    May be worth getting car up on ramp and get those bushes inspected, there are 4 no in total.
  8. Re: Front suspension knock
    Dec 2013
    Liverpool
    10 Post(s)
    Do you have the part numbers for the subframe bushes??
  9. Re: Front suspension knock
    Aberdeen
    63 Post(s)
    Apologies if this is obvious, but did you have weight on the suspension when you torqued them up?
  10. Re: Front suspension knock
    Sep 2020
    South Wales
    Quote Originally Posted by peter goble View Post
    Not got them yet, deciding how to tackle first as apparently a bit of a mare to do - the sub frame holds the engine mounts, so need an engine hoist to hold engine, plus remove all suspension arms from the frame…. Then pull the sub frame out - about 8 hours work!
    You are better off getting the car in the air and getting someone to check those bushes.
    Have you checked your caliper springs? Its not the pads knocking about?
    By peter goble in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 25-07-2020, 01:02 PM
  2. Help. Knock from d/s front suspension
    By Jdot in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 02-02-2016, 04:39 PM
  3. Front suspension knock
    By Dave Avant in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-07-2009, 03:49 PM
  4. Audi A6 front suspension knock
    By rosssomerville in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 24-03-2009, 12:04 AM
  5. Front suspension knock....
    By randall977 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-02-2009, 11:12 AM
