Thread: Passat 2002 : Comfort control module controller not reachable
Page 4 of 4 FirstFirst ... 234
Results 31 to 33 of 33
  1. Re: Passat 2002 : Comfort control module controller not reachable
    #31
    Nov 2006
    No Mate, if you have it handy will help.
  2. Re: Passat 2002 : Comfort control module controller not reachable
    #32
    Dec 2008
    14 Post(s)
    3 big philips bolts behind the pull handle/window controls and 2 small torx bolts along the bottom. Then pull away, releasing 3 press studs down each side, and lift upwards off lip of door (easiest with the window rolled down). Unplug connectors and cable to door handle as required. Getting to the 3 big bolts is the trick, where you pull the door closed you need to pry out a piece of plastic holding the handle in place. I suggest you google replacing doorlock or window regulator on a B5 and find one that is for the drivers door to see how to do it.
  3. Re: Passat 2002 : Comfort control module controller not reachable
    #33
    Nov 2006
    Ok, will google for more details. Will post an update once done. Thanks again Ianhayter.
  1. Passat comfort control module harness repair
    By redman in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-05-2019, 07:09 AM
  2. 2002 A6 Rhd Comfort control module.
    By stoddy2k in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 11-02-2015, 01:05 PM
  3. passat 2.0 sport 2002 wet footwell comfort module destroyed
    By toma69 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-02-2010, 12:02 AM
  4. comfort control module
    By logic5 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-02-2010, 05:54 PM
  5. Question How to program comfort control module for VW Passat
    By justscottish in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-01-2009, 07:59 PM
