Thread: Door lock removal
  1. Door lock removal
    Jul 2015
    glasgow
    I am surprised i dont know this one, anyway my rear door lock is in safe mode so i cant open the door. I have been on Ewrin but cant see how to get door open to replace the lock.
    Sent from my SM-G981B using Tapatalk
  2. Re: Door lock removal
    Jul 2015
    glasgow
    Fault codes clearly showing its electrical
  3. Re: Door lock removal
    1837 Post(s)
    If the catch is jammed, there is no approved method for releasing it, the only method is pure butchery. We used to get this a lot on the Passat 3B but we don’t see many of those any more. The worst is the Golf 5 as after removing the door panel you are greeted with a steel panel that you cannot remove… at least on the Golf 6 there is a little access from behind but it is often still necessary to cut the panel and weld the section back in after.
  4. Re: Door lock removal
    Jul 2015
    glasgow
    Thanks for the reply defo be getting left for now as i dont have the time for that
  1. Replies: 22
    Last Post: 18-01-2022, 05:45 PM
  2. Replies: 0
    Last Post: 02-02-2015, 11:16 AM
  3. Replies: 0
    Last Post: 12-01-2012, 07:07 PM
  4. Passenger door Lock removal - Help Non Electrical - Wind up
    By f2raf in forum Golf MK4 - 1999 - 2004
    Last Post: 03-10-2011, 09:58 AM
  5. Question golf v door lock removal
    By peter bates in forum Golf MK5 - 2004 - 2009
    Last Post: 19-05-2008, 10:37 AM
