Thread: Audi A6 avant c7 2.0tdi fault codes
Results 1 to 10 of 10
  1. Audi A6 avant c7 2.0tdi fault codes
    Jan 2015
    Inverness
    Our car has had a previous issues with some the fault codes attached below and Audi replaced the wiring loom on the near side to the braking system at a cost of £800 I now have the codes come on again and are becoming more frequent, I am assuming this again is a wiring issue and don’t expect the offside of the car wiring to be any different in terms of corrosion or the same issue as the nearside, I will be booking the car back in to Audi, just thought I would post the scan on here incase someone can see any other potential issues with any of the modules that might be playing up and make sure I’m not shelling out another £800 for it being an issue elsewhere,
    Going by the timing of the codes it would suggest one issue has thrown the rest of the codes up,
    Also the tpms - abs - parking angle to steep - electric handbrake lights and messages all come on and disappear for a while before intermittently coming back on they also clear as soon as you stop and restart the car, although the airbag warning light stayed on tonight and I also had the coil light on too, see copy of scan below
    I appreciate any advice,
    Code:
    Address 09: Cent. Elect.       Labels: 4H0-907-063-V1.clb
    Control Module Part Number: 4H0 907 063 CF    HW: 4H0 907 063 F
      Component and/or Version: BCM1 2.0      H12 0130
               Software Coding: 2600A01041349F600481008300001D0C0F9D870827090201000004606100
                Work Shop Code: WSC 02391 785 00200
                          VCID: 6ED9375BB9D965FB21-803A
    4 Faults Found:
    01321 - Control Module for Airbags (J234)
                 Freeze Frame:
                        Fault Status: 00100100
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 90
                        Mileage: 131916 km
                        Time Indication: 0
                        Date: 2021.09.28
                        Time: 19:09:00
    01314 - Engine Control Module
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 90
                        Mileage: 131916 km
                        Time Indication: 0
                        Date: 2021.09.28
                        Time: 19:09:00
    00473 - Control Module for Elect. Park/Hand Brake (J540)
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 90
                        Mileage: 131916 km
                        Time Indication: 0
                        Date: 2021.09.28
                        Time: 19:09:00
    00466 - Control Module for Steering Column Electronics (J527)
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 90
                        Mileage: 131916 km
                        Time Indication: 0
                        Date: 2021.09.28
                        Time: 19:09:00
                    Address 46: Central Conv.       Labels: 4H0-907-064-46.clb
    Control Module Part Number: 4H0 907 064 DN    HW: 4H0 907 064 DN
      Component and/or Version: BCM2 2.0      H35 0510
               Software Coding: 013B0622A0B930408320090400010F470000000000000000000000000000
                          VCID: 78F51103CB9D2B4BFB-802C
    4 Faults Found:
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 90
                        Mileage: 131916 km
                        Time Indication: 0
                        Date: 2021.09.28
                        Time: 19:09:41
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 90
                        Mileage: 131916 km
                        Time Indication: 0
                        Date: 2021.09.28
                        Time: 19:09:41
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 90
                        Mileage: 131916 km
                        Time Indication: 0
                        Date: 2021.09.28
                        Time: 19:09:42
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 90
                        Mileage: 132446 km
                        Time Indication: 0
                        Date: 2021.09.30
                        Time: 18:11:53
    4 Faults Found:
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 90
                        Mileage: 131916 km
                        Time Indication: 0
                        Date: 2021.09.28
                        Time: 19:09:41
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 90
                        Mileage: 131916 km
                        Time Indication: 0
                        Date: 2021.09.28
                        Time: 19:09:41
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 90
                        Mileage: 131916 km
                        Time Indication: 0
                        Date: 2021.09.28
                        Time: 19:09:42
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 90
                        Mileage: 132446 km
                        Time Indication: 0
                        Date: 2021.09.30
                        Time: 18:11:53
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 03 05 08 09 10 15 16 17 19 3B 42 44 46 47 52 53 55 5F 62
              6D 72
    VIN: WAUZZZ4G2EN084354   Mileage: 132476km-82316miles
    01-Engine -- Status: Malfunction 0010
    05-Acc/Start Auth. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    3B-Sensor Elect. -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: Malfunction 0010
    55-Headlight Range -- Status: Malfunction 0010
    5F-Information Electr. -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
       Part No SW: 03L 906 018 LA    HW: 03L 906 018 JL
       Component: R4 2.0l TDI   H25 9978
       Revision: 45H25---
       Coding: 12194012242401080000
       Shop #: WSC 56526 001 1048576
       ASAM Dataset: EV_ECM20TDI01103L906018LA 003012
       ROD: EV_ECM20TDI01103L906018GT.rod
       VCID: 74ED2533DFF54F2BD7-8020
    10 Faults Found:
    4698 - Function Restriction due to Faults in Other Modules
              U1113 00 [032] - -
              Intermittent - Not Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 6
                        Fault Frequency: 3
                        Mileage: 131917 km
                        Date: 2021.09.28
                        Time: 19:11:24
                        Engine RPM: 930.00 /min
                        Normed load value: 17.6 %
                        Vehicle speed: 10 km/h
                        Coolant temperature: 82 °C
                        Intake air temperature: 18 °C
                        Ambient air pressure: 1000 mbar
                        Voltage terminal 30: 14.580 V
                        Unlearning counter according OBD: 39
                        Cruise Control System (CCS): switch position-Bits 0-7: 0
                        Cruise Control System (CCS): status-Bits 0-7: 204
                        Cruise control switch-off: irreversible-Bits 0-7: 6
                        Cruise control switch-off: reversible-Bits 0-7: 255
                        Cruise Control System: specified speed: 0.00 km/h
                        Engine control module reset status-Bits 0-7: 0
                        Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
    4699 - Function Restriction due to Faults in Other Modules
              U1113 00 [032] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Mileage: 131917 km
                        Date: 2021.09.28
                        Time: 19:11:24
                        Engine RPM: 931.00 /min
                        Voltage terminal 30: 14.560 V
    5250 - Function Restriction due to Faults in Other Modules
              U1113 00 [032] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Mileage: 131957 km
                        Date: 2021.09.28
                        Time: 20:23:47
                        Engine RPM: 1840.00 /min
                        Normed load value: 0.0 %
                        Vehicle speed: 99 km/h
                        Coolant temperature: 79 °C
                        Intake air temperature: 8 °C
                        Ambient air pressure: 970 mbar
                        Voltage terminal 30: 14.400 V
                        Unlearning counter according OBD: 38
                        Longitudinal acceleration: raw value: 32.767 m/s²
                        Vehicle inclination acceleration angle: raw value: 32.767 m/s²
                        Status: incline angle-Bits 0-7: 1
                        Longitudinal acceleration: -0.192 m/s²
                        Longitudinal acceleration sensor: status-Bits 0-7: 1
                        Vehicle lateral acceleration: raw value: 327.67 g
                        Vehicle lateral acceleration: 0.00 g
    4708 - No Communications with HVAC Control Module (J301)
              U0164 00 [032] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 4
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:40
                        Engine RPM: 791.00 /min
                        Normed load value: 36.9 %
                        Vehicle speed: 255 km/h
                        Coolant temperature: 91 °C
                        Intake air temperature: 23 °C
                        Voltage terminal 30: 12.780 V
                        Unlearning counter according OBD: 40
                        Limitation: accelerator pedal: 0.0 Nm
                        CAN status - engine control module-Bits 0-7: 0
                        Cruise Control System (CCS): status-Bits 0-7: 205
                        CAN status - transmission control module-Bits 0-7: 0
                        CAN status - brake control module 1-Bits 0-7: 0
                        CAN status - brake control module 2-Bits 0-7: 0
                        selected gear-Bits 0-7: 0
    4713 - No Communication with ABS Brake Control Module
              U0121 00 [032] - -
              [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 4
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:40
                        Engine RPM: 782.50 /min
                        Normed load value: 31.4 %
                        Vehicle speed: 0 km/h
                        Voltage terminal 30: 12.680 V
                        Cruise Control System (CCS): status-Bits 0-7: 15
    4714 - Steering Column Control Module
              U0212 00 [032] - No Communications
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 4
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:40
                        Normed load value: 36.5 %
                        Voltage terminal 30: 12.740 V
    4715 - No Communication with Instrument Cluster
              U0155 00 [032] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 6
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:40
                        Normed load value: 31.0 %
                        Voltage terminal 30: 12.600 V
    4719 - No Communication with Diagnostic Gateway
              U0146 00 [032] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 5
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:40
    4720 - Body Control Module (Central Electric 2)
              U0141 00 [032] - No Communications
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 4
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:40
                        Engine RPM: 790.50 /min
    18177 - Gear Reconition Sensor
              P181E 00 [032] - Gear Position Implausible
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 131918 km
                        Date: 2021.09.28
                        Time: 19:13:58
                        Engine RPM: 1608.50 /min
                        Normed load value: 39.2 %
                        Coolant temperature: 80 °C
                        Voltage terminal 30: 14.260 V
                        Neutral position sensor: current transmission angle: 20.00 °
                        Neutral position sensor: adapted transmission angle: 0.00 °
                        Transmission neutral position sensor voltage: 0 mV
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes (J104)       Labels:. 4G0-907-379-V1.clb
       Part No SW: 4G0 907 379 L    HW: 4G0 907 379 L
       Component: ESP PREMIUM   H09 0450
       Revision: --------    Serial number: --------------
       Coding: 06A09F016005F9809B00
       Shop #: WSC 02391 785 00200
       ASAM Dataset: EV_ESPPremiAU57X 004039
       ROD: EV_ESPPremiAU57X_004_AU57.rod
       VCID: 3A71CB0BBD11F95BCD-806E
    12 Faults Found:
    0044 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              Intermittent - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 90
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:40
                        VzRef: 1D
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 24
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: AB
                        Uz: BA
    0051 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 90
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:40
                        VzRef: 1D
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 24
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: B7
                        Uz: BA
    0069 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 90
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:40
                        VzRef: 1D
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: E7
                        Uz: BA
    0071 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 90
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:40
                        VzRef: 1D
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: F4
                        Uz: BA
    0073 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 90
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:40
                        VzRef: 1D
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: F9
                        Uz: BA
    0075 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 90
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:40
                        VzRef: 1D
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 24
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: FC
                        Uz: BA
    0077 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 90
                        Mileage: 132446 km
                        Date: 2021.09.30
                        Time: 18:11:49
                        VzRef: 00
                        Bit Info 1: 80
                        Bit Info 2: 62
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 01
                        F-Type: 01
                        Uz: A6
    0518 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 88
                        Mileage: 131956 km
                        Date: 2021.09.28
                        Time: 20:23:46
                        VzRef: 63
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        F-Path: 01
                        F-Type: 0D
                        Uz: BA
    0091 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 90
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:40
                        VzRef: 1D
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        F-Path: 01
                        F-Type: 10
                        Uz: BA
    0486 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 89
                        Mileage: 131957 km
                        Date: 2021.09.28
                        Time: 20:23:47
                        VzRef: 63
                        Bit Info 1: 00
                        Bit Info 2: 42
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        F-Path: 02
                        F-Type: 08
                        Uz: BA
    0787 - Function Restriction due to Implausible Message(s)
              U1112 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 2
                        Reset counter: 89
                        Mileage: 132169 km
                        Date: 2021.09.29
                        Time: 15:34:27
                        VzRef: 08
                        Bit Info 1: 00
                        Bit Info 2: 42
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: EA
                        Uz: BB
    0834 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 89
                        Mileage: 132169 km
                        Date: 2021.09.29
                        Time: 15:34:26
                        VzRef: 0A
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        F-Path: 02
                        F-Type: 26
                        Uz: BC
    Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
       Part No SW: 4H0 907 064 DN    HW: 4H0 907 064 DN
       Component: BCM2 2.0      H35 0510
       Revision: 00002001
       Coding: 03B93046000000000000
       Subsystem 2 - Part No SW: 4H0 905 852 C    HW: 4H0 905 852 C
       Component: J764 ELV MLB  H40 0046
       Serial number: 0213000338754010
    1 Fault Found:
    01330 - Central Control Module for Central Convenience (J393)
                013 - Check DTC Memory - Intermittent
                 Freeze Frame:
                        Fault Status: 00101101
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 90
                        Mileage: 131916 km
                        Time Indication: 0
                        Date: 2021.09.28
                        Time: 19:09:41
    Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
       Part No SW: 4G0 820 043 AK    HW: 4G0 820 043 AK
       Component: KLIMA 2 ZONEN H14 0094
       Serial number: 04111300110613
       Coding: 34220008A1
       ASAM Dataset: EV_AirCondiBasisUDS 004002
       ROD: EV_AirCondiBasisUDS_004.rod
       VCID: 68D54143933DBBCB6B-803C
    3 Faults Found:
    0247 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 8
                        Reset counter: 90
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:47
                        Outside temperature: 12.5 °C
                        Engine RPM: 1478 /min
                        Vehicle speed: 37.00 km/h
    0260 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 3
                        Reset counter: 90
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:40
                        Voltage terminal 30: 14.38 V
                        Terminal 15 status: Terminal 15 on
    0331 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 90
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:41
                        Voltage terminal 30: 14.29 V
    Address 09: Cent. Elect. (J519)       Labels:. 4H0-907-063-V1.clb
       Part No SW: 4H0 907 063 CF    HW: 4H0 907 063 F
       Component: BCM1 2.0      H12 0130
       Revision: 20012002    Serial number: 00000001651408
       Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS57X 131007  H36 0080
       Serial number:         131009131926
       Coding: 0045F7
       Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
       Component: G397_RLFS  H06 0002
       Serial number: 21924426
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 S    HW: 4G0 941 531 S
       Component: E1 - LDS  H07 0044
       Serial number: 07 11 2013  00000586
       Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
       Component: Humidity_Sens  H03 0002
       Serial number: E54988D6000000000001
    4 Faults Found:
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 90
                        Mileage: 131916 km
                        Time Indication: 0
                        Date: 2021.09.28
                        Time: 19:09:00
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 90
                        Mileage: 131916 km
                        Time Indication: 0
                        Date: 2021.09.28
                        Time: 19:09:00
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 90
                        Mileage: 131916 km
                        Time Indication: 0
                        Date: 2021.09.28
                        Time: 19:09:00
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 90
                        Mileage: 131916 km
                        Time Indication: 0
                        Date: 2021.09.28
                        Time: 19:09:00
    Address 10: Park/Steer Assist (J446)       Labels:| 4H0-919-475-7X2.clb
       Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
       Component: PARKHILFE ACC H01 0083
       Revision: 11001001    Serial number: 61061331500518
       Coding: 08C208
       ASAM Dataset: EV_EPHVA18AU57X0000 004009
       ROD: EV_EPHVA18AU57X0000_004.rod
       VCID: 71E32C27A0E77A033C-8024
    2 Faults Found:
    12658704 - Databus
              U1121 00 [008] - Missing Message
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 90
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:40
    12648448 - Databus
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 90
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:40
    Address 15: Airbags (J234)       Labels:* 4H0-959-655.clb
       Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
       Component: Airbag10.43   H43 0040
       Revision: --------    Serial number: 003JG00FHRS$
       Coding: 3032343631324E303235554A305234473053
       ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
       ROD: EV_AirbaAU10BPAAU64X_VW51.rod
       VCID: 3669DF3B89091D3B29-8062
       Crash sensor for side airbag: driver side:
       Serial number: 3575HRB400Q50NTM818T
       Front Passenger's Side Airbag Crash Sensor:
       Serial number: 3585HRB40552A84E317A
       Rear Side Airbag Crash Sensor (on driver's side):
       Serial number: 3515JRB400K50PGECH0C
       Passenger side rear thorax airbag crash sensor:
       Serial number: 3525JRB400K50NQKB9Q1
       Crash sensor for front airbag: driver side:
       Serial number: 3554VRB401C50N8ES93L
       Crash sensor for front airbag: front passenger side:
       Serial number: 3564VRB401C50N8ENHAW
    No fault code found.
    Address 16: Steering wheel (J527)       Labels:. 4H0-953-568.clb
       Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
       Component: Lenks.Modul   H05 0201
       Revision: 00000000    Serial number: 20131107000022
       Coding: 000015
       VCID: 3065E923636D330B73-8064
       Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
       Component: E221 - MFL  H08 0010
    3 Faults Found:
    01316 - ABS Control Module
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 5
                        Reset counter: 90
                        Mileage: 131916 km
                        Time Indication: 0
                        Date: 2021.09.28
                        Time: 19:09:40
    01312 - Powertrain Data Bus
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 90
                        Mileage: 132446 km
                        Time Indication: 0
                        Date: 2021.09.30
                        Time: 18:11:53
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 90
                        Mileage: 132446 km
                        Time Indication: 0
                        Date: 2021.09.30
                        Time: 18:11:53
    Address 17: Instruments (J285)       Labels:| 4H0-920-xxx-17.clb-SRI1
       Part No SW: 4G8 920 984 H    HW: 4G8 920 984 H
       Component: TDieGb        H58 0621
       Revision: 29460233    Serial number: 658221013596037
       Coding: 33AD11000B412600010000
       ASAM Dataset: EV_RBD4K 004048
       ROD: EV_RBD4K_AU57.rod
       VCID: 3B7FCE0FB22BC053D6-806E
    3 Faults Found:
    16776962 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 90
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:40
    16776967 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 90
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:40
    16776971 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 90
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:40
    Address 19: CAN Gateway (J533)       Labels:* None
       Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
       Component: J533--Gateway H13 0050
       Revision: --------    Serial number: 00000001158728
       Coding: 00CD074400
       ASAM Dataset: EV_GatewPkoUDS 001019
       ROD: EV_GatewPkoUDS_001_AU57.rod
       VCID: 72E1232BA5E1411BC5-8026
       Battery Monitoring Control Module:
       Subsystem 1 - Part No SW: 8T0 915 181     HW: 8T0 915 181
       Component: J367-BDMHella  H03 8041
       Serial number: 5971331703
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 8K0 959 663 F    HW: 8K0 959 663
       Component: J532_DCDCStab  H23 0021
       Serial number: 1309050000000000017D
    10 Faults Found:
    4224 - No Communication with Engine Control Module (SAE ECM/PCM)
              U0100 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 88
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:41
                        Voltage terminal 30: 14.0 V
                        Voltage terminal 15: 14.3 V
                        Control Module temperature: 30 °C
                        System status: Terminal 15 on
                        IN ESP_standstill flag: no standstill detected
                        Engine running: On
                        IN ZAS_Te_X: On
                        Terminal 15 status via CAN: On
                        Terminal 15 status: On
                        Datenfeld: 0
    4356 - No Communications with Parking Brake Control Module
              U0128 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 88
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:41
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    4230 - No Communications with Steering Angle Sender (G85)
              U0126 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 88
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:41
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    4160 - No Communications with Airbag Control Module
              U0151 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 3
                        Reset counter: 90
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:41
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    4228 - No Communication with ABS Brake Control Module
              U0121 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 88
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:41
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    6655 - Sensor electronics control module
              U1077 00 [008] - No communication
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 88
                        Mileage: 131956 km
                        Date: 2021.09.28
                        Time: 20:23:46
                        Voltage terminal 30: 14.2 V
                        Voltage terminal 15: 14.4 V
                        Control Module temperature: 36 °C
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    0256 - Powertrain Databus
              U0001 00 [008] - Unspecified Malfunction
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 3
                        Reset counter: 90
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:40
                        Control Module temperature: 29 °C
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    0257 - Powertrain Databus
              U0002 00 [008] - No Communications
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 2
                        Reset counter: 90
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:41
                        Voltage terminal 30: 14.1 V
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    0274 - FlexRay-Data bus
              U1048 00 [008] - defective
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 3
                        Reset counter: 88
                        Mileage: 131956 km
                        Date: 2021.09.28
                        Time: 20:23:46
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 4
    16384 - Function Restriction due to Driver Fatigue Recognition
              B130E 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 88
                        Mileage: 131996 km
                        Date: 2021.09.28
                        Time: 20:48:54
                        Control Module temperature: 34 °C
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    Address 3B: Sensor Elect. (J849)       Labels: 4G0-907-637.clb
       Part No SW: 4G0 907 637 H    HW: 4G0 907 637 D
       Component: SARA 3D       H03 0056
       Revision: --------    Serial number: EJ1BPA720775WB
       Shop #: WSC 00000 000 00000
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 336FE62F9A7B08130E-8066
    Address 42: Door Elect, Driver (J386)       Labels:. 4H0-959-793.clb
       Part No SW: 4G8 959 793 J    HW: 4G8 959 793 G
       Component: TSG FA        H03 0507
       Coding: 011C16004001620002080002
       VCID: 4797A2FFF6E394B342-8012
    2 Faults Found:
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 90
                        Mileage: 132446 km
                        Time Indication: 0
                        Date: 2021.09.30
                        Time: 18:11:53
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 90
                        Mileage: 132446 km
                        Time Indication: 0
                        Date: 2021.09.30
                        Time: 18:11:53
    Address 44: Steering Assist (J500)       Labels:| 4G0-909-144.clb
       Part No SW: 4G0 909 144 L    HW: 4G0 909 144 G
       Component: RCEPS         H39 0010
       Revision: 00001000    Serial number: 0004012294
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: 3261E32B6561011B05-8066
    2 Faults Found:
    3158274 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 90
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:40
                        Write only channel
    3158276 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 90
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:40
                        Write only channel
    Address 46: Central Conv. (J393)       Labels:. 4H0-907-064-46.clb
       Revision: 00002001    Serial number: 0319753529
       Subsystem 1 - Part No: 4G0 951 177
       Component: DWA-Sensor  H01 0010
       Subsystem 2 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HO  H05 1501
    4 Faults Found:
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 90
                        Mileage: 131916 km
                        Time Indication: 0
                        Date: 2021.09.28
                        Time: 19:09:41
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 90
                        Mileage: 131916 km
                        Time Indication: 0
                        Date: 2021.09.28
                        Time: 19:09:41
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 90
                        Mileage: 131916 km
                        Time Indication: 0
                        Date: 2021.09.28
                        Time: 19:09:42
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 90
                        Mileage: 132446 km
                        Time Indication: 0
                        Date: 2021.09.30
                        Time: 18:11:53
    Address 47: Sound System (J525)       Labels: None
       Part No SW: 4G0 035 223 C    HW: 4G0 035 223 A
       Component: BOSE-G3-C7    H07 0160
       Revision: CJ007001    Serial number: 00000000049429
       Coding: 010000
       VCID: 1D3B209704FFAE63C8-8048
    Address 52: Door Elect, Pass. (J387)       Labels:. 4H0-959-792.clb
       Part No SW: 4G8 959 792 J    HW: 4G8 959 792 G
       Component: TSG BF        H03 0507
       Coding: 011C16004401620002080002
       VCID: 4689AFFBF1E98DBBB9-8012
    2 Faults Found:
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 90
                        Mileage: 132446 km
                        Time Indication: 0
                        Date: 2021.09.30
                        Time: 18:11:53
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 90
                        Mileage: 132446 km
                        Time Indication: 0
                        Date: 2021.09.30
                        Time: 18:11:53
    Address 53: Parking Brake (----)       Labels: 4H0-907-801.clb
       Part No SW: 4H0 907 801 G    HW: 4H0 907 801 A
       Component: EPB-4         H03 0014
       Revision: --------    Serial number: 00000000872086
       ASAM Dataset: EV_ParkiBrake 001028
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2C5DFD53474557EB4F-8078
    10 Faults Found:
    328448 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 6
                        Reset counter: 90
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:40
                        Voltage terminal 30: 14.6 V
                        Internal Fault ID: 89
                        Vehicle speed: 30 km/h
                        Network management state: normal
                        Function light in parking brake button: OFF
                        Red operating lamp: OFF
                        Red warning lamp: OFF
                        Green operating lamp: OFF
                        Yellow warning lamp: OFF
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        ACC requested apply: not active
                        Auto Adjust: not active
                        General Inspection Function: not active
                        Internal Parking Brake state: Dynamic
                        Status of parking brake button: Not operated
                        Status ParkingBrake left: Open
                        Status ParkingBrake right: Open
    328704 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 5
                        Reset counter: 90
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:40
                        Internal Fault ID: 90
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    328960 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 5
                        Reset counter: 90
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:40
                        Internal Fault ID: 91
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    329216 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 6
                        Reset counter: 90
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:40
                        Internal Fault ID: 92
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    329472 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 4
                        Reset counter: 90
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:39
                        Internal Fault ID: 93
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    330240 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 90
                        Mileage: 132169 km
                        Date: 2021.09.29
                        Time: 15:34:27
                        Voltage terminal 30: 14.7 V
                        Internal Fault ID: 96
                        Vehicle speed: 510 km/h
                        Yellow warning lamp: On
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        Internal Parking Brake state: static
    330496 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 4
                        Reset counter: 90
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:39
                        Internal Fault ID: 97
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    334336 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 90
                        Mileage: 132446 km
                        Date: 2021.09.30
                        Time: 18:11:48
                        Voltage terminal 30: 12.3 V
                        Internal Fault ID: 154
                        Function light in parking brake button: On
                        Red operating lamp: On
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        Status ParkingBrake left: applied
                        Status ParkingBrake right: applied
    335360 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 90
                        Mileage: 132169 km
                        Date: 2021.09.29
                        Time: 15:34:25
                        Internal Fault ID: 209
                        Vehicle speed: 8 km/h
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    406528 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 8
                        Reset counter: 90
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:39
                        Internal Fault ID: 215
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    Address 55: Headlight Range (J431)       Labels:| 8X0-907-357.clb
       Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
       Component: ....LWR12.... H02 0010
       Serial number: 131111-0001-046
       Coding: 112296101000A300
       ASAM Dataset: EV_HeadlRegulBasic 005001
       ROD: EV_HeadlRegulBasic_AU21.rod
       VCID: 2D5BF0577C5F5EE358-8078
    2 Faults Found:
    0095 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 90
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:40
    336388 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 90
                        Mileage: 131916 km
                        Date: 2021.09.28
                        Time: 19:09:40
    Address 5F: Information Electr. (J794)       Labels: None
       Part No SW: 4G0 035 192 H    HW: 4G0 035 192 F
       Component: RMC Nav Plus  H54 0801
       Coding: 0101010101415B47082B060301020100000000
       VCID: 2757027F56A374B3A2-8072
       Subsystem 1 - Part No: 8X0 919 884 E
       Component: P18-50-12.06  0001
       Subsystem 2 - Part No SW: 4G0 919 603 B    HW: 4G0 919 603 B
       Component: DU6 Basic  H43 0084
       Serial number: 9464J$0D2636334
       Subsystem 3 - Part No SW: 4G2 919 710 B    HW: 4G2 919 710 B
       Component: E380 BDT C7  H11 0204
       Serial number: 90349MJU000GL
    Address 62: Door, Rear Left (J388)       Labels:. 4H0-959-795.clb
       Part No SW: 4G8 959 795 J    HW: 4G8 959 795 G
       Component: TSG HL        H03 0507
       Coding: 010814004001620002080002
       VCID: 4993A4C7E0F762C354-801C
    Address 6D: Trunk Elect. (----)       Labels:* Redir Fail!
       Part No SW: 4G9 959 107 B    HW: 4G9 959 107 A
       Component: HDSG-Modul    H03 0143
       Revision: 14003001    Serial number: 291300813
       Coding: 097205C010
       ASAM Dataset: EV_HDSGAu572 001022
       ROD: EV_HDSGAu571.rod
       VCID: 356BD837940F162320-8060
    Address 72: Door, Rear Right (J389)       Labels:. 4H0-959-795.clb
       Component: TSG HR        H03 0507
    End-------------------------(Elapsed Time: 04:30)--------------------------
    2010 S4 Avant 3.0T Ice silver
    VCDS owner
  2. Re: Audi A6 avant c7 2.0tdi fault codes
    1837 Post(s)
    Most of that happened Tuesday evening all at the same time, to me it suggests water in the CAN BUS controller or the water box but you having an early VCDS lead hampers remote diagnostics because so much info is missing.
  3. Re: Audi A6 avant c7 2.0tdi fault codes
    Jan 2015
    Inverness
    Hi Crasher,
    Thanks for your reply much appreciated,
    I am in the process of getting my interface traded in for the newer version, I realise there’s a lot of info missing there,
    This is well over my head…. Don’t want to mess about with anything and cause more issues… I’ll get I booked in and see what they are saying, cheers Steve all the best 💪🏻
  4. Re: Audi A6 avant c7 2.0tdi fault codes
    1837 Post(s)
    The type 4G is starting to rival the 4B for goldfish bowl syndrome, the most common fault I see is aftermarket LED rear lights allowing water into the rear which causes havoc.
  5. Re: Audi A6 avant c7 2.0tdi fault codes
    Jan 2015
    Inverness
    Crasher all that modules are on the power train canbus I am assuming they aren’t all sitting in a box together and would possibly point to either one module failing and throwing the rest into fault or water ingress or corrosion to wiring somewhere along the line, I am concerned Audi are going to throw parts at this till it stops!!aye my bank balance 🤣 🙈 I hear you on the goldfish bowl, I seem to see lights on more often than not just now, good old Scottish weather won’t be helping the cause…
  6. Re: Audi A6 avant c7 2.0tdi fault codes
    Aug 2009
    cheshire
    6 Post(s)
    98 Post(s)
    Have a look in the spare tyre well as water can get in there and damage modules. Also the right cubby hole is an issue too. One module going down or contact corrosion on the CAN pair loses all comms on that line hence the loss of so many modules
    RS6 Performance Ascari Blue, Carbon Ceramics Brakes and lots more.
    A6 BiTdi Avant MTM
    Retrofitted: Full Led Headlights, DAB, Full Electric Seats, Surround View Cameras, Genuine RS6 Grille, RS6 Seats,Leather Door Armrests, Soft Close Doors, Rear Side Blinds,High Beam Assist, Eibach Springs, Led Roof Console, 4 Zone Climate, Rear Heated Seats, Head Up Display, Side assist, Alcantara Interior Retrim
  7. Re: Audi A6 avant c7 2.0tdi fault codes
    Jan 2015
    Inverness
    Thank you I’ll take a look and check this areas… much appreciated as always 👍🏻
  8. Re: Audi A6 avant c7 2.0tdi fault codes
    1837 Post(s)
    Mrs Crasher had to come back from Glen Coe a few weeks ago, the little flying biting ******** were eating her alive.
  9. Re: Audi A6 avant c7 2.0tdi fault codes
    Jan 2015
    Inverness
    Aye it’s the best form of torture for sure 🤣
  10. Re: Audi A6 avant c7 2.0tdi fault codes
    Jan 2015
    Inverness
    Also petition signed 👌🏻
    1 2 0
  1. 2.0TDI BMR Cut out not starting, injector fault codes.
    By allan_audi in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-10-2023, 11:58 AM
  2. Please Help CNHA 2.0TDI 190 ultra fault codes
    By Sambor11 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 05-08-2020, 09:07 PM
  3. Audi A4 Avant 3.0 tdi loss of power fault codes.
    By razor37 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-06-2014, 10:22 PM
  4. Please Help A4 b8 2.0tdi fault codes - help!
    By chrisroffey in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 24-02-2014, 10:40 PM
  5. Please Help A3 Sportback (sport) 2.0TDI 140 Fault Codes (55 plate)
    By Gomez in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 01-06-2011, 11:37 PM
