Thread: Engine Coil Light / Actuator
  1. Engine Coil Light / Actuator
    Nov 2014
    Stratford-upon-Avon, Warwickshire, United Kingdom
    Hey,
    So just got my car back from the garage after it went into limp mode and they believe from the live data that the Actuator is not holding pressure as much as it needs to.
    Does anyone know if you can replace this as a single component or if you need to replace the whole turbo?
  2. Re: Engine Coil Light / Actuator
    108 Post(s)
    1816 Post(s)
    Which engine and did they give you a fault code?
  3. Re: Engine Coil Light / Actuator
    Nov 2014
    They did not give me a fault code, it’s a 59 plate 2.0 GTD TDI
  4. Re: Engine Coil Light / Actuator
    108 Post(s)
    1816 Post(s)
    Private message me the reg
  5. Re: Engine Coil Light / Actuator
    108 Post(s)
    1816 Post(s)
    Yes there is a repair kit, VAG number 03L 198 716 L and is £206.46 but I had become a little used to this not being an issue anymore, we used to do a lot but it had died off. Setting it up is a quite delicate job.
  1. Question Stop start malfunction, pre heat coil light, engine light
    By jcdub in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 10-12-2016, 12:49 PM
  2. Please Help Hesitation / power loss, flashing coil light, solid engine light and "Engine Failure Worshop!" warning
    By MHDxMK5BK in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-06-2014, 10:02 PM
  3. uh oh... coil light and engine management lit up
    By Phil K in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 17-10-2013, 10:50 PM
  4. Please Help Engine Management Light (coil symbol)
    By rob1990 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-12-2009, 09:33 AM
  5. 06 Polo TDi coil light and engine symbol light on
    By Grazuncle in forum Polo - Derby - Lupo - Fox
    Last Post: 01-09-2009, 04:19 PM
