Changed Discs, pads and brake oil today. Only problem is I cannot for the life of me work out how to get to the clutch bleed screw (can't even see it from the top or the bottom) - even tried with a scope to see it but no luck!
Elsawin says to remove the left heatshield around the drive shaft but there is no way to get at the top bolt from what I can see without lowering the gear box (which I can't do).
Any thoughts would be great?
