Thread: Oil pan gasket replacement
  1. Oil pan gasket replacement
    Sep 2013
    Europe
    Hi guys!
    Have a -89 Mk2 with leaning oil sump pan gasket. Thought I'd have it a go replacing it myself on the parking lot with raised front. Will it be easily doable? Anything in particular to have in consideration while on the task?
  2. Re: Oil pan gasket replacement
    135 Post(s)
    2026 Post(s)
    Which engine size?
    1 1 0
  3. Re: Oil pan gasket replacement
    Sep 2013
    Europe
    Which engine size?
    Thanks for a Uber-quick response, I never thought I'd get one since this sub-forum seems kind of abandoned, heh.
    Anyways, yeah, I should have mentioned it on my original post, it's the 1.8l "RP" engine with manual transmission.
  4. Re: Oil pan gasket replacement
    135 Post(s)
    2026 Post(s)
    I am a Golf 2 fanatic. All you need is a one reach 1/4” drive extension bar and ratchet plus a short read check socket, the extension bar need to have a “wobbly end” as to remove the two screws into the flywheel oil seal holder you do not get a direct path and have to work offset. This shouldn’t cause you any problem in removal but take great care putting them back in as it is easy to cross thread into the alluvium seal holder and that is box out and clutch off. It seems to be almost impossible to get a perfect leak free seal and I have tied all sorts, Golf 3 rubber metal, sealant on composite and rubber gases and dry, all seem to weep. The best results I have had are with the “windage” tray plate design which is rubber/metal and assembled spotlessly dry, possibly the design is more stable? This is a 2 litre conversion to a DX block into an 84 Scirocco we built just before lockdown and is coming back from paint soon.
  1. Sump gasket replacement
    By H&O2008 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-04-2014, 08:20 AM
  2. Please Help MK4 GTI Camcover Gasket Replacement.
    By AndySil in forum Golf MK4 - 1999 - 2004
    Last Post: 10-10-2011, 09:28 PM
  3. Manifold Gasket Replacement
    By deanwhiting920 in forum Golf MK2 - 1984 - 1992
    Last Post: 02-07-2010, 05:47 PM
  4. Sump gasket replacement
    By Last Triumph in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-06-2009, 04:41 PM
  5. Head Gasket Replacement
    By pnuckched in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 03-12-2006, 10:43 AM
