Thread: Gearbox compatibility?
  1. Gearbox compatibility?
    Sep 2021
    Kent
    I have a 2014 Audi A4 B8 2.0 tdi technik 177 it has the MVT gearbox, the box has had it! A friend has a LLM gearbox out of a 2010 2.0 tdi does anyone know if it will fit or work?
  2. Re: Gearbox compatibility?
    108 Post(s)
    1816 Post(s)
    Both 01B series with a 3.09 final drive but I would have to trawl through the other ratios as the ECU can pick up even slight differences.
  3. Re: Gearbox compatibility?
    Sep 2021
    Kent
    Thankyou for the info! where could I find the other ratio information? or would you be able to help me with this?
  4. Re: Gearbox compatibility?
    108 Post(s)
    1816 Post(s)
    I would have to sit down with the parts system ETKA and go through the ratios of each gear and compare, I am off work after an opp and I can’t get access to ETKA as the virtual machine I set up before going off won’t work and I can’t drive or lift anything… trapped!
  5. Re: Gearbox compatibility?
    Sep 2021
    Kent
    Ahh sorry to hear that man, and apologies just would love to find out then I might be able to use the box he’s given me. Thankyou anyway and maybe you could have a look when your back at work if you have the time I can pay you. Anyway I don’t expect that’s a priority for you anytime time, I would like to wish you a speedy recovery and at least thank you for the information you have given me so far. Many thanks
  6. Re: Gearbox compatibility?
    108 Post(s)
    1816 Post(s)
    I will be off for a few weeks, struggling to come to terms with such deep muscle cuts.
  1. Gearbox code compatibility
    By boatingcow in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 25-10-2020, 05:27 PM
  2. Gearbox compatibility
    By lecar in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 16-09-2017, 10:02 PM
  3. DSG gearbox compatibility codes
    By dangerdan in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 01-07-2015, 06:04 PM
  4. Gearbox compatibility
    By mosebone in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-12-2009, 12:20 AM
  5. audi a4 gearbox compatibility
    By kingdong01 in forum Chat - Anything with wheels
    Last Post: 14-11-2007, 07:21 AM
