Thread: Broken tappet finger/follower 3.0tdi
  1. Broken tappet finger/follower 3.0tdi
    Sep 2021
    Reading UK
    Hi. I have a misfire on cylinder 5 which I was hoping was just an injector. I have removed the injector and then noticed in the top of the engine a bit of loose metal. I have fished out with a magnet two pieces of a follower. It looks like both inlet followers have gone. What would cause this?
    My next step is to take the rocker cover off and have a good look in there and see if I can find the rest of the broken bits.
    Can the followers be fitted without taking the cam and cam carrier off.
  2. Re: Broken tappet finger/follower 3.0tdi
    1840 Post(s)
    I can’t imagine how you can do that without a full chain strip down, a £15 part causing that much grief! If it is one cylinder then I should not cause a misfire like on the older 2.5 when they used to spit their fingers out; you only found out when two inlet/exhaust on the sae cylinder came out so there is going to be more to this. How many miles?
  3. Re: Broken tappet finger/follower 3.0tdi
    Sep 2021
    Reading UK
    Hi Crasher.
    its done about 120k. I’m hoping to take the rocker cover off today to have a good look in the top of the bank. I can see the top of the two inlet valves so I assume when its running they arent opening hence the misfire. Chances are the bore was been washed with diesel for a while now which may have caused premature wear. I may be scrapping this car.
  4. Re: Broken tappet finger/follower 3.0tdi
    1840 Post(s)
    I agree, it sounds very expensive to fix; with the electric cars coming, scrapping a perfectly good 15 or so year car old due to a huge bill is something the world is going to have to get used to.
  5. Re: Broken tappet finger/follower 3.0tdi
    Sep 2021
    Reading UK
    I removed the rocker cover. I think the chain has jumped as 4 followers have been broken. I think the car will be broken.
    anyone want anything off it??
  6. Re: Broken tappet finger/follower 3.0tdi
    1840 Post(s)
    Yes, that’s engine out partial strip down, a new cam or two
  1. How to debadge an A4 B8 with one finger
    By mag911 in forum Audi
    Last Post: 07-01-2014, 11:33 AM
  2. A8 3.0tdi 2005 broken timing chain tensioner
    By jaggafeen in forum A8 - S8 - V8
    Last Post: 14-02-2011, 03:59 PM
  3. Question Broken rear spring on 21K '05 2.0TDI DSG
    By Hillbeley in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 23-04-2009, 06:50 PM
  4. A6 2.5 TDI 2002 broken follower
    By Broken in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 29-01-2009, 04:30 PM
  5. a4 error; finger pointing @ ??
    By nordica5 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-07-2007, 02:55 AM
