Thread: Changing the rear pads and maybe discs too
  1. Changing the rear pads and maybe discs too
    Oct 2019
    Peterborough, England
    23 Post(s)
    On my 4.2 tdi D3.
    I have access to Vag-COM. But I keep seeing conflicting methods to release the calipers on the EPB.
    some use the release brake method in the menu and then seem to be able to just push the pistons back in.
    Others use the release caliper method and wind the pistonss back in with the 3 pointed tool.
    which is correct?
    Then you tell the menu you have new pads at 13 mm and it closes up OK.
    thanks.
  2. Re: Changing the rear pads and maybe discs too
    135 Post(s)
    2040 Post(s)
    From memory (not at work) the type 4E Audi A8 uses TRW rear calipers and winding them back in the style of the mechanical type destroys their internals; the brake pad thickness needs to be entered into the EPB ECU using a diagnostic system.
  3. Re: Changing the rear pads and maybe discs too
    Oct 2019
    23 Post(s)
    Ace. Thank you.
    Sounds like the same as the fronts, with use of a G-Clamp.
    Will give it a go.
  4. Re: Changing the rear pads and maybe discs too
    135 Post(s)
    2040 Post(s)
    I wouldn’t, you will need to apply pressure to the plastic motor body, thankfully I bought an ATE piston return tool about 40 years ago and hardly ever used it until these came along.
  5. Re: Changing the rear pads and maybe discs too
    Oct 2019
    23 Post(s)
    Oh, a reverse g-glamp type thing?
  6. Re: Changing the rear pads and maybe discs too
    135 Post(s)
    2040 Post(s)
    As long as the pressure is applied to the piston and the two fingers of the fist
  1. Question Does anyone have any advice for changing break discs and pads?
    By battmiceter in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 11-01-2013, 10:15 PM
  2. help with changing rear brake pads and discs
    By Alaska in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-04-2010, 09:26 AM
  3. Changing Pads & Discs
    By Stuart_B in forum Golf MK4 - 1999 - 2004
    Last Post: 24-06-2009, 12:56 PM
  4. Question Changing discs/pads
    By danclyon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-11-2008, 12:09 AM
  5. Changing front brake pads and discs
    By KevBrowne in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-01-2008, 10:39 PM
