Thread: Passat B7 1.6tdi CAYC glow plugs
  1. Passat B7 1.6tdi CAYC glow plugs
    Jun 2021
    lincoln
    Morning all.
    I've got the above car. 2014 plate. Glow plug 3 is u/s and I'm going to have all 4 done. Been quoted £150-£200 all in.
    My question is that when I asked about this I was told glow plug 3 may have a pressure sensor on it too. Can anyone with this engine or knowledge confirm it does?
    Whenever I do a check on euro parts or auto doc I'm not offered one when using my reg. Just the standard ones. Bosch being about £10 per plug.
    Many thanks
    Dan
  2. Re: Passat B7 1.6tdi CAYC glow plugs
    1840 Post(s)
    The CAYC uses conventional plugs
  3. Re: Passat B7 1.6tdi CAYC glow plugs
    Jun 2021
    lincoln
    Brilliant thank you
  1. A3 CAYC 1.6Tdi Starts then stops after a few seconds - brake fault
    By Jon44w in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-11-2020, 10:24 AM
  2. Question VW Passat 1.6tdi 2012 Flashing glow plug light
    By Yasir53 in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 18-01-2020, 02:26 PM
  3. Please Help CAYC Passat 1.6tdi 2012 p253600
    By Adots in forum 1.6TDi - Engine
    Last Post: 07-12-2019, 12:38 AM
  4. Question 1.6tdi CAYC Engine
    By djah in forum Golf MK6 - 2009 - 2013
    Last Post: 11-07-2019, 05:20 PM
  5. Please help vw passat 1,6tdi cayc
    By dorin in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 08-03-2018, 09:23 AM
