Thread: How does it take the management unit going to sleep
  1. Cool How does it take the management unit going to sleep
    May 2020
    Margam United Kingdom
    Hi there Guys & Gals
    I am about to trace a current drain on my A3 1.9Tdi P1
    I will be opening the bonnet and driver’s door (to gain access to the fuse box) I will then latch both of those so that the management unit thinks that the bonnet and door are closed.
    My question how long does it take for this unit to go to sleep ?
    Also what reading will I get on my multimeter showing that it HAS gone to sleep ?
    Any helpful advice would be much appreciated
    Tony
  2. Re: How does it take the management unit going to sleep
    1840 Post(s)
    If the CAN BUS can see the car is locked it goes down consumption in two stages, dropping to a very low drain after a few minutes.
  3. Re: How does it take the management unit going to sleep
    May 2020
    Many thanks for your contribution
    So if I plug in my OBD before I latch the bonnet (not close) and latch the door (not close) what would my OBD read >
  4. Re: How does it take the management unit going to sleep
    1840 Post(s)
    It is not the sort of data VAG provide but I like to see no more than 0.03 amp but it is often nearer 0.07 and that takes the battery below starting point in about 2 weeks which is typical of a modern car.
  1. Electrical Fault - car not going to sleep mode - Battery Drain Audi A4 2007
    By willywill in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-09-2018, 09:51 PM
  2. A6 gone into sleep mode
    By Bloobat in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-01-2010, 09:56 PM
  3. Where does your baby sleep at night...
    By 73kingstonroad in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-07-2009, 02:18 PM
  4. Please Help 2005 Polo - Engine Management Unit Problem
    By Kathryn1980 in forum Polo - Derby - Lupo - Fox
    Last Post: 20-05-2009, 07:06 AM
  5. Not going into sleep mode???
    By NaveedN in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-08-2008, 10:08 PM
