Thread: 1.9 td 99' t4 knocking
  1. Exclamation 1.9 td 99' t4 knocking
    Please help I have an ABL engine which the cam belt slipped on I have rebuilt with a new head and belt kit but it has a knock similar to a diesel knock but 5 different mechanics are stumped
    Has any one had a similar problem
    If not which other engine codes with replace the ABL with just a few modifications
    PLEASE PLEASE HELP
    Sam
  2. Re: 1.9 td 99' t4 knocking
    I’m assuming that this engine has an ‘ecu’, so really my first option would be to get it plugged into a computer running vag-com to see if there are any errors reported. Check that all the sensor cables aren’t damaged as a broken wire could be the fault.
    chris
  3. Re: 1.9 td 99' t4 knocking
    Quote Originally Posted by carbon View Post
    Cheers carbon but this is an earlier engine no such luck but thanks for your suggestion
  4. Re: 1.9 td 99' t4 knocking
    Sorry about that.
    Did you set the injection timing with a dial guage and the cold start aid fully in?
    chris
  1. a6 knocking
    By stuartliddell in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 09-07-2007, 10:23 PM
  2. V6 Big End Knocking!!!!!!!
    By burtoxcbr in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 05-07-2007, 10:03 PM
  3. Steering Knocking
    By MikeA4tdi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-05-2007, 09:38 AM
  4. Knocking when idling?
    By MarkMk3 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 21-02-2007, 12:39 PM
  5. knocking
    By bigb1970 in forum Passat - Archive Topics
    Last Post: 04-07-2006, 01:38 PM
