Thread: Coolant Shut of Valve
  1. Coolant Shut of Valve
    Oct 2020
    United Kingdom
    Hello everybody
    I do have 2 fault codes in my car and I need your help guys add pictures of the faults
    If I do get understand myself the fault codes for Additional coolant pump?
    Fault codes B10C813 Coolant shut-off valve
    B10C811 Coolant shut-off valve
    Car Audi A6 C7 2013 2.0tdi 130kw
    Thank you for your help
    1804202059350-01 — ImgBB
    Screenshot-20210919-093552-OBDeleven — ImgBB
    Screenshot-20210919-093602-OBDeleven — ImgBB
  2. Re: Coolant Shut of Valve
    Jun 2023
    Norway
    Hei man do you fix it and if you do how .
  1. Coolant leak - Culprit is the Coolant inlet valve seal
    By inchshort in forum Q7 - 4M Forum - 2016 -
    Last Post: 06-01-2024, 08:48 PM
  2. Question 2011 Passat 2.0 TDI CFFB Engine - can you use VCDS to lock shut EGR valve
    By drjohnbullas in forum VCDS - General Questions
    Last Post: 18-06-2019, 08:30 PM
  3. Please Help Audi 2.5 Throttle Shut Off Valve + Housing
    By audirjb in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 06-08-2009, 11:18 PM
  4. EGR VAlve Shut off
    By VEEDUBYA in forum Passat - Archive Topics
    Last Post: 22-05-2007, 10:35 PM
  5. EGR Valve Shut off
    By VEEDUBYA in forum Archive posts
    Last Post: 02-05-2007, 09:21 PM
