Thread: Gear change problems on my 1.9tdi 130hp 6 speed gear box
  1. Gear change problems on my 1.9tdi 130hp 6 speed gear box
    Sep 2021
    Penzance uk
    Hello,
    I wonder if anyone can help me, my gear stick seems like it's come lose, it goes round in circles, getting into reverse is difficult, come out of first is hard work, going from 2nd into 3rd and 4th is not to bad, I was able to go into 5th and 6th, but now that is not happening anymore, and reverse is getting more difficult to find,
    Would it be the gear stick that needs replacing, or could it be the linkage on the gearbox itself, I have the Haynes workshop manual, but it dosent seem to mention anything about a circlip that seems to hold my gear stick in position, all it says is remo e 2 nuts and lift it out but it does not happen, I want to remove the circlip to see if it will come out, but then I'm worried that I might have a problem getting it back,
    Apparently it says in the manual there is some kind of adjustment to be made underneath the gearstick, the gear box and clutch seem fine, no whining noises or anything, so I'm at a point now whether to buy a new linkage with a ball type joint that goes to gearbox, or get a new gear stick, has anyone ever had sutch a problem and is it an easy fix thanks kev
  2. Re: Gear change problems on my 1.9tdi 130hp 6 speed gear box
    1840 Post(s)
    The squeeze clip clamps the base of the knob around the stick.
  1. Gear oil part number? 1.9TDi 5 speed manual
    By chapster in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-06-2013, 09:09 AM
  2. Please Help golf 1.9tdi (55 reg) gear selection problems
    By monkeynuts81 in forum Golf MK5 - 2004 - 2009
    Last Post: 02-07-2011, 08:31 PM
  3. Gear change problems
    By mattdolan in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-02-2011, 09:17 PM
  4. gear change problems
    By konrad1 in forum Golf MK4 - 1999 - 2004
    Last Post: 05-10-2008, 05:59 PM
  5. 130 TDI 6 Speed Gear oil change-Sealed or not.
    By Big G in forum Golf MK4 - 1999 - 2004
    Last Post: 05-08-2008, 10:24 AM
