Thread: Audi A3 2.0TDI random cut outs.
Results 1 to 10 of 11
  1. Audi A3 2.0TDI random cut outs.
    Sep 2021
    Manchester
    Hi everyone I recently bought a car from a dealership, when I went to buy the car, it was cutting out power all on a sudden. The dealer said he got it fixed so I test drove the car and all fine, he said Audi reprogrammed the ECU which was the issue but it is doing it again. It cuts out at any RPM so I doubt it would the turbo as it cuts out even at below 2000 rpm and the car engine never stalls like fully off.Idle is perfectly stable so I doubt it’s the MAF or faulty injectors. I think it could be the fuel pump? Anyone could give me any suggestions on what could the problem be? The car is a Audi A3 8V 2.0TDI 2015 150ps STronic
  2. Re: Audi A3 2.0TDI random cut outs.
    1840 Post(s)
    Start with a full vehicle code read, print of the results, clear the codes, drive it again until it plays up and then re-read and print, post the results on here.
  3. Re: Audi A3 2.0TDI random cut outs.
    Sep 2021
    Manchester
    Hi Crasher thanks for your time apparently there are no codes stored into the ECU. Overnight I have read many other forums where owners spent a lot of money and time and it turned out to be their fuel pump. Even Audi said the car looks healthy and there is no issue and then here we go with the problem again.
  4. Re: Audi A3 2.0TDI random cut outs.
    1840 Post(s)
    If there were any fuel pressure issues they are picked up by the ECU and stored with time, date, speed, rpm etc info. About the only two devices that can randomly fail without leaving a code are the engine speed sensor and the ECU relay, if it was the crank speed sensor then this leaves a clue in that when the engine cuts out the rev counter reading drops to zero rather than following the speed at which the vehicles motion is turning the engine.
  5. Re: Audi A3 2.0TDI random cut outs.
    Sep 2021
    Manchester
    Hi crasher I will have a look into this and the engine has started to die evens when the car is idling but still the idle is stable on the car.
  6. Re: Audi A3 2.0TDI random cut outs.
    1840 Post(s)
    Very symptomatic of the crank speed sender.
  7. Re: Audi A3 2.0TDI random cut outs.
    Sep 2021
    Manchester
    Do you mean crankshaft sensor by that?
  8. Re: Audi A3 2.0TDI random cut outs.
    1840 Post(s)
    Yes, also known as the G28
  9. Re: Audi A3 2.0TDI random cut outs.
    Sep 2021
    Manchester
    Thanks for answering Crasher but I’m wondering why wouldn’t it throw a code on the dash?
  10. Re: Audi A3 2.0TDI random cut outs.
    1840 Post(s)
    It won’t bring on the Malfunction Indicator Light or the emissions light, in many cases even the ECU doesn’t register it as a fault.
  1. Audi A5 amp pre-outs
    By kgthomas in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 25-05-2016, 11:57 AM
  2. Audi amp pre-outs
    By kgthomas in forum In Car Entertainment
    Last Post: 23-05-2016, 08:21 AM
  3. Random cut-outs
    By easy tiger in forum Golf MK3 - 1993 - 1999
    Last Post: 31-12-2009, 04:56 PM
  4. Please Help 1.6 Mk3 - Random cut outs - electrical?
    By listerthrawn in forum Golf MK3 - 1993 - 1999
    Last Post: 23-03-2009, 03:54 PM
  5. Audi S6 ins and outs?
    By DanGerMus in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 21-02-2009, 03:05 PM
