Thread: Gearbox Malfunction error showing up sporadically
Hybrid View
  1. Gearbox Malfunction error showing up sporadically
    Sep 2021
    Leeds
    Hi there,
    Hope somebody can help me. I have a 2014 A6 2.0 TDI Multitronic and for the past few days a 'Gearbox Malfunction - you can continue driving' error shows up alongside a Check engine light. The error its self disappears almost immediately and the CEL goes away overnight only to return a few miles in to my next journey.
    The car seems to be driving fine, I can't recall any issues with the gear changes or getting it in to Drive, Park or Reverse at any point.
    I have already been under the car and checked for the coolant leak issue that I've seen pop up on my google searches and the coolant valve and the plug in to the gearbox are dry as a bone.
    A friend of mine put a scan tool on and got the following error
    P171E00 Passive/Sporadic
    Transmission Input Speed (RPM)
    Sensor 2
    No Signal
    Does anybody on here have any idea what the issue could be and if it's something I could perhaps tackle myself. The guy I've used in the past for auto gearboxes is unable to get me in until after the 13th so I'd rather try and find the issue before then.
    Thanks in advance.
  2. Re: Gearbox Malfunction error showing up sporadically
    134 Post(s)
    2007 Post(s)
    The 0AW transmission speed sensor is part of the Mechatronic unit.
  3. Re: Gearbox Malfunction error showing up sporadically
    May 2022
    Wakefield UK
    Hi, I have the same car with the same issue did you get it resolved if so how ? Thanks in advance. Adrian
  4. Re: Gearbox Malfunction error showing up sporadically
    Sep 2023
    Danija
    did you find the problem?
  5. Re: Gearbox Malfunction error showing up sporadically
    134 Post(s)
    2007 Post(s)
  1. gearbox malfunction a6 c7 allroad 2012
    By chris.d in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 06-06-2021, 09:28 PM
  2. Gearbox malfunction
    By Dazlav@aol.com in forum Chat - Adult Banter
    Last Post: 13-04-2021, 01:46 PM
  3. Question Gearbox Malfunction
    By JayNana in forum A7 - S7
    Last Post: 23-03-2017, 04:58 PM
  4. Replies: 2
    Last Post: 12-08-2016, 07:35 PM
  5. limp mode 8 error codes showing please help !
    By blobby in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-11-2010, 09:19 PM
