Thread: Check Engine Light On - Codes 16517, 17501, 18669
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. Check Engine Light On - Codes 16517, 17501, 18669
    Jul 2018
    Birmingham, West Midlands
    8 Post(s)
    Hi need help with the following codes that have come up in the engine module....
    CEL is on dashboard.....
    Is this a bad O2 sensor? It was replaced with a Bosch part not too long ago so I wouldn't think it was that.
    Could that change from E5 to E10 unleaded fuel be causing an issue here?
    Any help would be appreciated.
    Code:
    Monday,06,September,2021,11:38:09:33544
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 21.9.0.1 (x64)
    Data version: 20210824 DS330.0
    www.Ross-Tech.com
    VIN: WVWZZZ1KZ4W096975   License Plate:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
    VIN: WVWZZZ1KZ4W096975   Mileage: 369830km-229801miles
    01-Engine -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    56-Radio -- Status: OK 0000
    Address 01: Engine        Labels: 03C-906-056-BAG.lbl
       Part No SW: 03C 906 056 BA    HW: Hardware No
       Component: MED9.5.10       G00 5697
       Revision: 00000000    Serial number: VWZ7Z0D9331576
       Coding: 0000072
       Shop #: WSC 01279 785 00200
       VCID: 63C1C201A2D6B0913F-8036
       VINID: 9E69EAAAA05BA849C024624714EDDC82ED
    3 Faults Found:
    16517 - Oxygen (Lambda) Sensor B1 S1
                P0133 - 002 - Response too Slow - Intermittent
    17501 - Bank 1; Fuel Measuring System 2
                P1093 - 008 - Malfunction - Intermittent
    18669 - Oxygen (Lambda) Sensor B1 S1
                P2237 - 008 - Pump Current Open Circuit - MIL ON
    Readiness: 0000 0000
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
       Part No: 1K0 907 379 K
       Component: ESP FRONT MK60      0103
       Coding: 0019073
       VCID: 3A7F5F6575DC91594C-806E
    No fault code found.
    Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
       Part No: 1K0 820 047 CB
       Component: Climatic PQ35   080 0201
       Shop #: WSC 00000 000 00000
       VCID: 66C7DB1551E4C5B9D8-8032
    1 Fault Found:
    00229 - Refrigerant Pressure
                002 - Lower Limit Exceeded
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-M.lbl
       Part No SW: 1K0 937 049 K    HW: 1K0 937 049 K*
       Component: Bordnetz-SG 1.0 H30 0701
       Revision: 00030000    Serial number: 00000000514812
       Coding: E48D0F0600041800001400001400000000
       VCID: 3779465146CE8C31B3-8062
       Subsystem 1 - Part No: 1K2 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer VW350  012  0401
       Coding: 00065493
       Shop #: WSC 00000
       Subsystem 2 - Part No: 1K0 955 559 K  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 002  0505
       Coding: 00217125
       Shop #: WSC 00000
    1 Fault Found:
    01049 - Supply Voltage Term 50
                006 - Short to Plus - Intermittent
    Address 15: Airbags        Labels: 1K0-909-605.lbl
       Part No SW: 1K0 909 605 A    HW: 1K0 909 605 A
       Component: 0M AIRBAG VW8   022 0500
       Revision: 04022000    Serial number: 0033FD08P0VC
       Coding: 0012365
       Shop #: WSC 01268 785 00200
       VCID: 2A5F6F25857C21D93C-807E
       Subsystem 1 - Serial number: 6332MSME5D7E1002
       Subsystem 2 - Serial number: 6342MSME57340A02
       Subsystem 3 - Serial number: 6351HSME43485801
       Subsystem 4 - Serial number: 6361HSME5D0F5901
    Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
       Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
       Component: Lenksäulenmodul 012 0030
       Coding: 0000022
       VCID: 306B7D4DA3A05B09F2-8064
    Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
       Part No: 1K0 920 950 K
       Component: KOMBIINSTRUMENT VDD 3554
       Coding: 0000401
       Shop #: WSC 00218 210 03908
    Address 19: CAN Gateway        Labels:. 1K0-907-530-V1.clb
       Part No SW: 1K0 907 530 C    HW: 1K0 907 951
       Component: Gateway         H08 0080
       Revision: 08          Serial number: 2100104128EF35
       Coding: 3D0F0340070003
       VCID: 27599611966E1CB123-8072
    Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
       Component: IMMO                3554
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
       Part No: 1K0 959 701 E
       Component: Tuersteuergeraet 09 0116
       Coding: 0000052
    Address 44: Steering Assist        Labels: 1Kx-909-144-G2V1.clb
       Part No: 1K2 909 144 E
       Component: EPS_ZFLS Kl.1       1202
       VCID: 2E576335B9944DF9E0-807A
    Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 BL
       Component: 01 KSG              0301
       Coding: 81E802087F2D8505485BC61000
       Shop #: WSC 00218 210 08203
       VCID: 7BF19A613A66685117-802E
       Subsystem 1 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HORN H05 1501
       Subsystem 2 - Part No: 1K0 907 719
       Component: Neigungssensor  003 0003
       Subsystem 3 - Part No: 1K0 951 177
       Component: Innenraumueberw.004 0101
    1 Fault Found:
    01134 - Alarm Horn (H12)
                004 - No Signal/Communication
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
       Part No: 1K0 959 702 E
       Coding: 0000052
       VCID: 316D7849A8AA5201FD-8064
    Address 56: Radio        Labels: 1K0-035-1xx-56.clb
       Part No: 1K0 035 186 J
       Component: Radio BNO           0016
       Coding: 0040400
       VCID: 2D556439B49236E1D9-8078
    End-------------------------(Elapsed Time: 01:36)--------------------------
  2. Re: Check Engine Light On - Codes 16517, 17501, 18669
    1841 Post(s)
    It is possibly the use of E10 BUT you should not be using 95RON with a BAG code engine. If you look inside the fuel flap you will see a sticker which says 98/(95) RON which means you must use a minimum octane of 98 RON except in exceptional circumstances and with reduced power.
  3. Re: Check Engine Light On - Codes 16517, 17501, 18669
    Jul 2018
    8 Post(s)
    OK thanks for the advice.
    If 98RON was being used what could be causing these codes?
    Prior to E10 being introduced I do remember running on 95RON with no issue really.
    If correct fuel is being used what could be causing these codes?
  4. Re: Check Engine Light On - Codes 16517, 17501, 18669
    1841 Post(s)
    The extra 5% of Ethanol could be causing the amount of trim applied by the ECU to exceed +10% but I just remembered these have a known problem with the wiring breaking in the section between the inner wing and the engine.
  5. Re: Check Engine Light On - Codes 16517, 17501, 18669
    Jul 2018
    8 Post(s)
    Have you got any images of the wiring issue?
    is this the wiring to lambda sensor or ECU? Or another part?
  6. Re: Check Engine Light On - Codes 16517, 17501, 18669
    1841 Post(s)
    No I haven't got any pictures of this on a Golf 5. The wiring goes directly from the Lambda sensors fly lead plug (on a bracket on the front of the gearbox) to the ECU without interruption where the wiring goes from the box to the body moves and can break but all the covering has to be stripped off to check.
  7. Re: Check Engine Light On - Codes 16517, 17501, 18669
    Jul 2018
    8 Post(s)
    Refilled the car with protection grade 99RON from shell (V power) and seemed to make a difference but the CEL came back on.....but has subsequently disappeared again after driving around...so appears to be intermittent.
    the car does feel like it is running rough with and without the CEL on....I’m wondering if I’ve caused more damaged using E10 fuel perhaps, constricted the fuel lines or ruined the injector seals?
    could this mean the wiring is knackered as described above?
    does the wiring go bad in the scuttle area where it passes from Ecu to the engine bay?
    i did do an overlay harness for the throttle body issue I had and that seemed to sort out another issue i had which put the car in limp mode.....depinned from the Ecu to the throttle body connector and replaced all 6 wires....
    will need the wiring diagrams for the lambada sensor (pre cat) if I am going to replace the wiring entirely. Are you able to send these across to me if possible? Just need to know what to depin at the ecu connector and which connector at that too as there are two of them.
    thanks for your help.
  8. Re: Check Engine Light On - Codes 16517, 17501, 18669
    1841 Post(s)
    I can't get it to print to file correctly, you can download everything for the car from https://erwin.volkswagen.de/erwin/showHome.do for €7 per hour
  9. Re: Check Engine Light On - Codes 16517, 17501, 18669
    Jul 2018
    8 Post(s)
    No worries I’ll take a look myself when I get a chance.
    How much would it cost to replace the complete engine harness? And what is the part number?
  10. Re: Check Engine Light On - Codes 16517, 17501, 18669
    1841 Post(s)
    The part number is 03C 972 619 M and it was £338.94 but went obsolete October last year and there is no UK TPS stock but I could not check the main dealers
  1. Question Check engine light on and engine vibrating when ignition turned off
    By sapstar in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-08-2021, 09:50 AM
  2. Question no crank, glow-plug light blinking and check engine light on.
    By rayrowie in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 26-03-2016, 02:17 PM
  3. Attention Check engine light (MIL, CEL light) not working
    By minty2013 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-09-2013, 08:57 AM
  4. audi low oil pressure light,check engine light
    By redviper131 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-05-2010, 06:51 PM
  5. Please Help 52 reg 1.4 16v Lupo SE has EPC light, Engine check light and stiff brake pedal
    By robbig in forum Polo - Derby - Lupo - Fox
    Last Post: 02-09-2008, 10:45 PM
