Thread: Check Engine Light On - Codes 16517, 17501, 18669
Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
  1. Re: Check Engine Light On - Codes 16517, 17501, 18669
    #21
    Mar 2010
    Derry ireland
    60 Post(s)
    the compressions on this vehicle should show at least 200 psi either at taken cold or hot. This requires a re-placement engine
  2. Re: Check Engine Light On - Codes 16517, 17501, 18669
    #22
    1840 Post(s)
    The A was a revised design supersession. I insist on the dial gauge reading 0, the crank locked against the pin (when there is a hole) and the locking plate to drop in an pull out without any fiddling.
  3. Re: Check Engine Light On - Codes 16517, 17501, 18669
    #23
    Jul 2018
    Birmingham, West Midlands
    8 Post(s)
    Thanks for the reply @mickeybo
    Where do you get this information from? I’ve never been able to find compression data specifically for engines before? Not even in the workshop manual from VW.....unless I have missed it somewhere?
    The engine in there now is actually a replacement engine that I got a few months ago. Had done half the mileage that mine had (old engine = ~220000, new engine ~110000).
    pressures for the bad engine were (it had a rough idle....engine was shaking).
    Cylinder 1 135psi
    Cylinder 2 100psi
    Cylinder 3 145psi
    Cylinder 4 140psi
  4. Re: Check Engine Light On - Codes 16517, 17501, 18669
    #24
    1840 Post(s)
    It is normally show in ELSA in the section on how to do it
  5. Re: Check Engine Light On - Codes 16517, 17501, 18669
    #25
    Jul 2018
    8 Post(s)
    Found this so think compressor pressures are ok.
    This is a for a BLF engine not a BAG but thought they would be similar?
  1. Question Check engine light on and engine vibrating when ignition turned off
    By sapstar in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-08-2021, 09:50 AM
  2. Question no crank, glow-plug light blinking and check engine light on.
    By rayrowie in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 26-03-2016, 02:17 PM
  3. Attention Check engine light (MIL, CEL light) not working
    By minty2013 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-09-2013, 08:57 AM
  4. audi low oil pressure light,check engine light
    By redviper131 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-05-2010, 06:51 PM
  5. Please Help 52 reg 1.4 16v Lupo SE has EPC light, Engine check light and stiff brake pedal
    By robbig in forum Polo - Derby - Lupo - Fox
    Last Post: 02-09-2008, 10:45 PM
