Thread: Check Engine Light On - Codes 16517, 17501, 18669
Results 11 to 20 of 25
  1. Re: Check Engine Light On - Codes 16517, 17501, 18669
    Jul 2018
    Birmingham, West Midlands
    8 Post(s)
    Car is running really rough idle is bad too.
    Any advice how to solve this?
    I used ODIS and followed the test plan for the 18669 fault codes.
    Went through the test plan and said it was ok.
    Not sure what else to look at?
    Could it be a mechanical issue?
    Or should i be checking the lambda wiring from the Ecu to the fly lead as you have suggested first?
  2. Re: Check Engine Light On - Codes 16517, 17501, 18669
    1834 Post(s)
    Compression and the valve timing checks. Have you cranked it over with the coil packs off but still connected to the harness?
  3. Re: Check Engine Light On - Codes 16517, 17501, 18669
    Jul 2018
    8 Post(s)
    What does cranking it over with the coil packs off do??
  4. Re: Check Engine Light On - Codes 16517, 17501, 18669
    Jul 2018
    8 Post(s)
    Yes I did crank the engine over with the coil packs off and still connected to the wiring harness when we did the compression check? Does this cause damage to the ECU or other components?
    Compression check was ok but cylinder 4 was slightly down.
    Cylinder 1 150psi 10bar
    Cylinder 2 150psi 10bar
    Cylinder 3 150psi 10bar
    Cylinder 4 137.5/140psi 9.5bar
    I’m suspecting maybe the timing is perhaps very slightly out??
    I will have to double check and make absolutely sure it’s ok.
  5. Re: Check Engine Light On - Codes 16517, 17501, 18669
    1834 Post(s)
    If you crank the engine with the coil packs unable to spark to earth it kills them instantly.
  6. Re: Check Engine Light On - Codes 16517, 17501, 18669
    Jul 2018
    8 Post(s)
    Ah ok well I replaced them anyway with brand new Bosch coils and NGK plugs as well discussed in another post I put up I think.
    So when doing compression or check or cranking always make sure the coil packs are disconnected from the wiring harness to avoid damage?
  7. Re: Check Engine Light On - Codes 16517, 17501, 18669
    #17
    1834 Post(s)
    Yes, very important
  8. Re: Check Engine Light On - Codes 16517, 17501, 18669
    #18
    Jul 2018
    8 Post(s)
    No worries I now know and won’t be doing that again.
    So think I’m going to check:
    1.) Valve Timing
    2.) Pre Cat Lambda Sensor (Bank 1 Sensor 1) Wiring (from ECU to fly lead).
    3.) Check condition of Lambda sensor (ensure heater circuit operating correctly as well).
    Shall report back my findings and hopefully get this rough running issue resolved.
    If there is anything else you think I should let me know.
    Thanks.
  9. Re: Check Engine Light On - Codes 16517, 17501, 18669
    #19
    1834 Post(s)
    If the valve timing is OK, you can check the condition of the full system including lambda sensors by generating the readiness code, there is a function for this in ODIS and VCDS.
  10. Re: Check Engine Light On - Codes 16517, 17501, 18669
    #20
    Jul 2018
    8 Post(s)
    I did do the readiness check a week ago or so and it passed.
    Followed the instructions on VCDS to complete the readiness and it passed.
    So perhaps it is a timing issue? Maybe chain has stretched?
    Will have to check to confirm.
    How easily does the camshaft locking tool have to go into the camshaft alignment holes? (T10171A)
    Is there a difference between the T10171 and T10171A?
  1. Question Check engine light on and engine vibrating when ignition turned off
    By sapstar in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-08-2021, 09:50 AM
  2. Question no crank, glow-plug light blinking and check engine light on.
    By rayrowie in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 26-03-2016, 02:17 PM
  3. Attention Check engine light (MIL, CEL light) not working
    By minty2013 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-09-2013, 08:57 AM
  4. audi low oil pressure light,check engine light
    By redviper131 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-05-2010, 06:51 PM
  5. Please Help 52 reg 1.4 16v Lupo SE has EPC light, Engine check light and stiff brake pedal
    By robbig in forum Polo - Derby - Lupo - Fox
    Last Post: 02-09-2008, 10:45 PM
