Thread: Oil sensor warning.
Results 1 to 8 of 8
  1. Oil sensor warning.
    Feb 2019
    Bexhill, England
    I have an oil sensor warning light come up on my 2003 2.4 ltr petrol V6 A4 Avant Estate B6.
    I’ve had a search on Google and, unusually, I can find no information on the subject? I don’t even know where the sensor is located and whether I can change it.
    Any advice on this problem would be gratefully received.
  2. Re: Oil sensor warning.
    1836 Post(s)
    Level or pressure?
  3. Re: Oil sensor warning.
    Feb 2019
    Bexhill, England
    Neither/I don't know. There is the oil 'can' picture and the word "sensor". The following image (I hope / visible to me before I POST QUICK REPLY) is one I found on the internet.
    The Owner's Manual states "If the OIL SENSOR symbol lights up, take the vehicle to an Audi dealer and have the oil level sensor checked. Until then it is advisable to check the oil level every time you fill up with fuel."
    The first thing I did was check the oil level and it was OK.
  4. Re: Oil sensor warning.
    Feb 2019
    Bexhill, England
    Are the two (or more) oil sensors?
    I would assume that the oil level sensor is on the sump?
    On other models of Audi I have seen (on YOUTUBE) that there is a sensor by the oil filter which I assume is the oil pressure sensor?
  5. Re: Oil sensor warning.
    1836 Post(s)
    That is the sensor in the sump, it changed for the 2003 model year so if your is a 2003, the current part number is 1J0 907 660 F
  6. Re: Oil sensor warning.
    Feb 2019
    Bexhill, England
    Thank you for the information and PN.
    I guess an oil drain/ change will be required (and new filter, of course). I’ll need one of those oil collection doobries too.
  7. Re: Oil sensor warning.
    Feb 2019
    Bexhill, England
    That’ll be this, then.
  8. Re: Oil sensor warning.
    Feb 2019
    Bexhill, England
    Turned out to be a broken wire / soldered / repaired.
  1. Please Help oil sensor warning problem.
    By audi bwoy in forum Golf MK4 - 1999 - 2004
    Last Post: 28-04-2011, 10:07 PM
  2. 2000 A6 2.5 TDI oil sensor warning
    By biggerbinns in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-04-2011, 09:25 PM
  3. Please Help A3 Oil Sensor Warning Light
    By jobbywotsit in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 01-11-2010, 04:28 PM
  4. Please Help Oil sensor warning
    By sishephard in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-02-2010, 07:35 PM
  5. Please Help Oil sensor warning
    By sishephard in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-02-2010, 07:22 PM
