Thread: PRNDS flashing - cannot connect to transmission with VCDS
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. Re: PRNDS flashing - cannot connect to transmission with VCDS
    Jul 2008
    The REG is LS02 LDV.
    However, the gearbox isn't original as I discovered doing this task.
    The stamp on the underside of the gearbox is FYU 276 (for an A4 3.0 litre model)
    The code on the actual TCM is 01J 927 156 ET.
    I also have PRNDS on the dashboard even though the car doesn't have sport. This was how it was given to me by Bristol Transmissions in 2014 (refurb @ £2400). Was told to ignore the S, it was something to do with coding update?
  2. Re: PRNDS flashing - cannot connect to transmission with VCDS
    1836 Post(s)
    This could be where you are running into problems as the box should be an FSC and the controller is completely wrong for the car so I can’t advise further with it being the wrong box.
  3. Re: PRNDS flashing - cannot connect to transmission with VCDS
    Jul 2008
    OK, fair enough.
    Thanks for responding.
    Regards
  4. Re: PRNDS flashing - cannot connect to transmission with VCDS
    Jul 2008
    Hi Crasher - looking for your advice regarding ATF refill for a multitronic cvt (2002). I think I have finally got a refurbished TCU that is not throwing up previous errors (PRNDS flashing on dashboard) or F125 in VCDS. I'm about to take it off ramps and give it a test drive.
    However, I'm concerned about ATF level. When I originally drained the fluid I got 5.5 litres out (cold). On the several attempts to get a working TCU I have drained and refilled gearbox but have only been able to get around 4.5 litres back in following audi workshop guidance (35 - 45 degree temp etc..). Yesterday I got 4.7 litres in so I feel it's still low.
    My question is, should I try adding more fluid with engine running, I've heard conflicting advice on this. The workshop manual doesn't mention this method?
  5. Re: PRNDS flashing - cannot connect to transmission with VCDS
    1836 Post(s)
    You MUST set the level with the engine running and with the temperature (shown in measuring blocks) between 30 and 40 degrees, we slightly over fill and bring the box up to temp and then remove the level setting plug at 30 degrees.
  6. Re: PRNDS flashing - cannot connect to transmission with VCDS
    Jul 2008
    Thanks for confirming that. I could only get an initial 4 litres in when cold, and then run the engine until fluid temp was 40 degrees. I couldn't get more in until I tried again with the engine running and then I got another 700ml in. I'll try and get some more in - need to order some more ATF.
    Regards
  7. Re: PRNDS flashing - cannot connect to transmission with VCDS
    #17
    Jul 2008
    Just out of curiosity, how do you flush these gearboxes to completely refresh the fluid?
  8. Re: PRNDS flashing - cannot connect to transmission with VCDS
    #18
    1836 Post(s)
    You have to use a special flushing rig or an air line
  1. Audi A6 Multitronic gearbox transmission ECU (“PRNDS” light fault)
    By Ted Hughes in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-03-2015, 06:48 PM
  2. Prnds light flashing
    By markspark71 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 14-08-2014, 10:05 PM
  3. Question Prnds flashing?
    By Shawrigg in forum Touran - Sharan - Caravelle
    Last Post: 13-04-2014, 09:44 AM
  4. Question PRNDS flashing
    By ChristopherF in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-02-2011, 10:50 AM
  5. Please Help PRNDS Flashing
    By GJC in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-10-2010, 10:36 AM
