Thread: Fault P1347 caused by failed cam chain adjustment unit (between cams)?
  1. Fault P1347 caused by failed cam chain adjustment unit (between cams)?
    Jul 2021
    Hampshire, UK
    2006 A8 V8 4.2 cam belt model (Pre FSI engine).
    Does anyone know if failure of the tensioner adjustment unit for the chain between cams in the same bank would result in a P1347 fault? I’m not sure where the cam sensor is-obviously if it’s on the exhaust cam I can’t see how it would bring up that code.
    Also, would failure of that chain adjuster potentially cause valve piston contact?
    Thanks everyone!
  2. Re: Fault P1347 caused by failed cam chain adjustment unit (between cams)?
    1841 Post(s)
    I would suspect the chains are worn and the timing out, it is a HUGE job.
  1. Question 00573 Fault code not caused by garage fixing gator?
    By benwrigley in forum Golf MK5 - 2004 - 2009
    Last Post: 24-06-2018, 11:36 PM
  2. Rear bump caused parking sensor fault
    By westiej in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-08-2013, 10:10 AM
  3. Replies: 1
    Last Post: 29-09-2011, 08:06 AM
  4. Question 02 Polo Timing Chain jump caused by Garage?
    By CassandraC in forum Polo - Derby - Lupo - Fox
    Last Post: 17-12-2010, 05:11 PM
  5. Did VCDS caused a stereo fault?
    By Axios in forum VCDS - Help Requests
    Last Post: 16-12-2010, 01:17 PM
