Thread: Exhaust Flap rattle - Audit RS4
  1. Exhaust Flap rattle - Audit RS4
    London
    The exhaust flap inside one of the rear part of the exhaust on my RS4 is rattling. With a soft stick, I can see if moves freely and is loose. I will run the VCDS exhaust check I've seen mentioned elsewhere.
    Is it likely that an owner with reasonable DIY skills can fix this rattling exhaust-box-valve. I'm wondering if replacement of the exhaust box is a practical and / or the only solution. On line I see that the exhaust box, with the solenoid / valve inside is about £450. Or is it feasible, advisable to access the interior workings of the exhaust-box and, say, screw it with a clip so it's permanently open.
    Any tips would be appreciated.
  2. Re: Exhaust Flap rattle - Audit RS4
    1840 Post(s)
    £901.25 per box...
  1. 2.0TFSI Wastegate Flap Rattle
    By Bern1150 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 27-07-2016, 08:04 PM
  2. Fuel flap rattle
    By Stratf01 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 28-06-2016, 02:19 AM
  3. Exhaust rattle at low revs
    By Wrightski in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 20-02-2014, 10:27 PM
  4. 110SE TDI - exhaust rattle?
    By urquattro in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-08-2010, 07:54 PM
  5. Exhaust rattle - 1.8T AUM - Bracket?
    By ad1966 in forum Golf MK4 - 1999 - 2004
    Last Post: 13-05-2009, 10:51 PM
