Thread: Mk6 golf gt tdi ignition problem
  1. Mk6 golf gt tdi ignition problem
    May 2020
    Glasgow
    Hi all go easy as im new and dont know if posting this in right place
    Im hoping someone can help/advise, my mk6 golf ingnition barrel decided to go very stiff wouldnt turn , so i got some graphite lock lubricant sprayed it into the barrell and it turned fine and started so i let it run a while then removed key and now it wont turn further than only just releasing the steering lock
    Will the barrel not come out now as i cant fully get it to the on position?
    Also if it will come out can it be removed without removing steering wheel etc ?
    I can get a barrell and door lock (2nd hand) from a mk6 1.4 tsi will that work using my original key fob on the 2nd hand keys blade? I was also told 1 from a mk5 golf would work is this true?
    Apologies for all the questions and long post im not great at tinternet
    Thanks and any advice will be gratefuly recieved as desperate to get car moving again
  2. Re: Mk6 golf gt tdi ignition problem
    1837 Post(s)
    The immobiliser is separate to the remote control and is coded to the instrument panel so you need to order from VW a lock barrel unit matched to the cars VIN, these take about two weeks to come from Germany. Usually the problem is the lock unit but often you can't get the barrel out as you can't put it into removal position so you end up replacing both.
  3. Re: Mk6 golf gt tdi ignition problem
    May 2020
    Glasgow
    Hi thanks for reply i see loads of the barrell/locks on ebay new so i had just assumed that using the 2nd hand barrel and key i could use my original key fob with iimo chip with 2nd hand keys blade fitted to my original fob as the 1s from ebay didnt mention about it bein specific to the cars vin i assumed you would just swap the fobs internals to key of new unit,
    So the new units from ebay would be pointless aswell then?
    I think maybe its beyond me and time to get professionals in
    Thanks for reply
  4. Re: Mk6 golf gt tdi ignition problem
    Mar 2016
    Minervois, France
    53 Post(s)
    The key turns a lot more than the lock barrel, so it could be something else that is stiff. See other posts on this subject, e.g. 55 plate touran ignition or steering lock problems?
    (Click on the underlined words)
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 79,125 kms = 49,450 miles on 30/07/23
  5. Re: Mk6 golf gt tdi ignition problem
    1837 Post(s)
    From a VW main dealers parts department you can order a new barrel for your car matched to the key data held by VW in Germany, this pops in and works. Part number 107 905 855 CF and £203.78 inc VAT retail. This is a Vehicle Intelligent Part ordered to your cars VIN and has to be paid for up front and is non returnable.
  1. Please Help Ignition problem
    By Simple82 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-01-2016, 06:20 PM
  2. Replies: 61
    Last Post: 27-02-2014, 06:23 PM
  3. Question ignition problem
    By jonnygfx in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-04-2012, 08:30 PM
  4. ignition problem
    By a-teamlambretta in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-02-2010, 05:55 PM
  5. Question golf gti 16v ignition barrel problem
    By tom22om in forum Golf MK3 - 1993 - 1999
    Last Post: 06-08-2009, 03:44 PM
