Thread: BKD Feels sluggish and engine noise
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. Re: BKD Feels sluggish and engine noise
    1836 Post(s)
    I use Flickr to host my own pictures
  2. Re: BKD Feels sluggish and engine noise
    Jul 2016
    United Kingdom
    Ah OK thanks, I'll just leave it. Just wanted to show the plastic boost pipe that comes down from the turbo has split both sides and air is pouring out when I test it with compressed air so I think that's my problem. Decided to take off all of the other boost pipes and check them and all the others seem good.
    Problem is I snapped off one of the retaining clips for the pipes so now I need a new one and a new pipe before I can drive it really, oops.
    I would have liked to replace it with a metal one really but I'm not sure ones from other models are compatible I think ill just go for a brand new one as I can see it being a common issue with used plastic pipes.
  3. Re: BKD Feels sluggish and engine noise
    Jul 2016
    United Kingdom
    Back again, fixed the boost leak but unfortunately it hasn’t solved all of my problems, just feels like the turbo is slow to start pulling once you get higher in the Rev range it starts pulling well but low end is just not good.
    When I rev the engine standing still it makes the owl type noise especially when letting off the accelerator and the revs drop. I’ve heard a lot of people saying this noise is normal but others saying it’s the turbo that’s bad, I checked the refurbished turbo for shaft play before I put it on and it felt pretty good very minimal play and no damage to the blades.
    I’m just concerned that I’ll end up swapping the turbo again and it will still be the same..
  1. Replies: 0
    Last Post: 30-01-2021, 04:30 PM
  2. Golf feels slow to spin up and sluggish
    By GSXRCarlos in forum Golf MK5 - 2004 - 2009
    Last Post: 26-05-2016, 04:18 PM
  3. 2.0tfsi feels like a cold diesel engine at low rpm
    By evolve in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-10-2015, 01:15 PM
  4. Problems with used A6 Low MPG...Engine feels like 140Bhp ..it has 10.000 miles
    By cip82 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 30-05-2012, 10:32 PM
  5. Feels like engine missing a beat on idle
    By phantomdox in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 15-02-2012, 11:05 PM
