Thread: Which fuse to tap for a dashcam
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. Re: Which fuse to tap for a dashcam
    Sep 2012
    Romford, UK
    Quote Originally Posted by Gazwould View Post
    This is good , please don't tell me you went with ignition off ?
    I did have to go with ignition off. The cutoff on the nextbase is 11.2V. didn't want to risk battery draining. These days my car just sits on the drive most of the time.
  2. Re: Which fuse to tap for a dashcam
    Mar 2016
    Minervois, France
    54 Post(s)
    I have a Nextbase dashcam, power supply is only with ignition on.
    I decided on this because, apart from it running the battery flat when the engine is not running, I don't see much point in having the camera on when the car is parked, because:
    1) If someone broke into the car they'd probably steal or destroy the dashcam
    2) If someone ran into the car in a supermarket car park they would probably hit the side of it, so wouldn't be seen by the front mounted camera, or a rear mounted camera if I had one.
    3) If someone hit the back of the car I would probably get a nice picture of the side of an unidentifiable car grazing the rear, as it's unlikely anyone would drive or reverse into the rear with enough speed to cause any damage. I don't worry about cars touching bumpers. That's what they're for.
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 86,533 kms = 54,083 miles on 18/11/2024
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  3. Re: Which fuse to tap for a dashcam
    May 2012
    Everywhere
    308 Post(s)
    You bought the wrong camera with no parking mode selectable shut down times .
    I left mine not to shut down as an experiment , 3 days no issue .
  4. Re: Which fuse to tap for a dashcam
    Mar 2016
    Minervois, France
    54 Post(s)
    What has your camera recorded/what do you expect it to record, when your car is parked, please?
    Do you also have a rear facing camera? If so, was this left on for your experiment?
    Also, what is the recording resolution of your camera? Mine is 2560 x 1440 pixels @ 30 fps. This gives continuous smooth movement and I can stop and enlarge individual frames on my 19" PC screen to easily read number plates at around 25 metres.
  5. Re: Which fuse to tap for a dashcam
    May 2012
    Everywhere
    308 Post(s)
    Supermarket car parks and alike , the number one high risk area is not to be ignored .
    Old car has front as I can't fit rear due to privacy shades .
    Newer has privacy glass and have two to go in , all 3 1440 P,
    25 fps .
    It does have a G shock wake up mode but it won't catch the actual incident , that's why it's left recording with no issue to the battery.
  6. Re: Which fuse to tap for a dashcam
    Mar 2016
    Minervois, France
    54 Post(s)
    What camera(s) do you have then, please?
  1. Which fuse for hardwired dashcam?
    By sammy.se in forum Vehicle Security - Retrofit / aftermarket alarms & immobilisers
    Last Post: 07-05-2021, 07:29 AM
  2. Fuse feed for dashcam - Car never powers down on some fuses?
    By chinnyhill10 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 07-01-2019, 01:17 PM
  3. Which fuse for dashcam acc/live?
    By Akash in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 19-02-2016, 07:17 PM
  4. dashcam
    By dieselal in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 10-12-2015, 05:08 PM
  5. Dashcam on A6
    By Warthog21 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 07-07-2015, 10:22 PM
