Thread: Which fuse to tap for a dashcam
Results 1 to 10 of 16
  1. Which fuse to tap for a dashcam
    Sep 2012
    Romford, UK
    Can someone please help me with a fuse ideal to connect the dash cam to? Preferably on the passenger side. I am looking for something which is off when the ignition if turned off.
  2. Re: Which fuse to tap for a dashcam
    Sep 2012
    Romford, UK
    I have taken couple of photos of the fuses and the fuse diagram on my passenger side. Can you please help me locate a fuse I can tap?
    I checked with a multi meter and the Fuse number 10 in the black fuses seems to turn on/off with ignition. It is marked as communication in the fuse diagram. Can I use this for the dashcam?
  3. Re: Which fuse to tap for a dashcam
    May 2012
    Everywhere
    308 Post(s)
    Having ignition off provides no footage in the highest risk area..
  4. Re: Which fuse to tap for a dashcam
    Sep 2012
    Romford, UK
    Quote Originally Posted by Gazwould View Post
    True, but don't want to risk battery going too low. I bought a nextbase hard wire kit which covers with some sort of battery protection, but I am not sure how good that is.
    Sent from my XQ-AT51 using Tapatalk
  5. Re: Which fuse to tap for a dashcam
    May 2012
    Everywhere
    308 Post(s)
    Normally rubbish with a too low 11.6V cut off .
    Basically you chose the wrong camera !
    I did let it solidly record for 3 days without issue .
  6. Re: Which fuse to tap for a dashcam
    Sep 2012
    Romford, UK
    Do you record from an Android phone? Or the camera you use runs on Android?
    I had a viofo a119s, but just ordered a Nextbase 512gw. Not sure there is any control in the camera.
  7. Re: Which fuse to tap for a dashcam
    May 2012
    Everywhere
    308 Post(s)
    App link via camera's WiFi .
    Go into a supermarket and camera records in the car park , it's not to be missed this high risk environment .
  8. Re: Which fuse to tap for a dashcam
    Sep 2012
    Romford, UK
    Can someone please help with this. I tried taking 5a, 10a and 15a fuses on the black row and all of them are still supplying power to the camera after ignition is off.
    I did check with a multi meter before installing and the original fuses was showing 0v before the ignition is turned off.
  9. Re: Which fuse to tap for a dashcam
    Sep 2012
    Romford, UK
    I am answering my own post . Number 9 in the second row did the job.
  10. Re: Which fuse to tap for a dashcam
    May 2012
    Everywhere
    308 Post(s)
    This is good , please don't tell me you went with ignition off ?
  1. Which fuse for hardwired dashcam?
    By sammy.se in forum Vehicle Security - Retrofit / aftermarket alarms & immobilisers
    Last Post: 07-05-2021, 07:29 AM
  2. Fuse feed for dashcam - Car never powers down on some fuses?
    By chinnyhill10 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 07-01-2019, 01:17 PM
  3. Which fuse for dashcam acc/live?
    By Akash in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 19-02-2016, 07:17 PM
  4. dashcam
    By dieselal in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 10-12-2015, 05:08 PM
  5. Dashcam on A6
    By Warthog21 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 07-07-2015, 10:22 PM
