Thread: Priming turbo oil feed
  1. Priming turbo oil feed
    Jul 2016
    United Kingdom
    Hi guys,
    Finally had my turbo off for rebuild due to it overboosting, anyway its all back on now, what's the best way to turn the engine over without it starting up fuel pump fuse maybe? Just want to prime the oil feed line before I run it.
    I should probably know this but its been a long day lol.. Thanks
    Forgot to mention its a 2.0 TDI BKD
  2. Re: Priming turbo oil feed
    Dec 2014
    Bedford
    42 Post(s)
    You could unplug the cylinder head loom to the injectors at the cylinder head. That would work.
    Sent from my SM-G970F using Tapatalk
  3. Re: Priming turbo oil feed
    1840 Post(s)
    Don't forget that this will leave a code that needs clearing.
  4. Re: Priming turbo oil feed
    Jul 2016
    United Kingdom
    Thanks guys all done
  1. Question Fuel priming system A3 petrol non-turbo
    By Mavtroll in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 01-10-2011, 12:46 AM
  2. changing turbo oil feed
    By passat 130 tdi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-11-2009, 02:56 PM
  3. turbo oil feed pipe
    By paulp in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-11-2009, 03:25 PM
  4. Oil Feed Line for Turbo
    By jonnocooper1987 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-04-2009, 08:40 AM
  5. Where can I get a turbo oil feed?
    By SilentBob in forum Archive posts
    Last Post: 12-06-2007, 09:12 AM
