Thread: G42 Sensor Help
Results 1 to 10 of 10
  1. Unhappy G42 Sensor Help
    Aug 2021
    Portugal
    Hello guys , can anyone help me with the Location of the G42 Sensor , Im having this error on VCDS (Air intake sensor ( G42 ) Signal to Low 112-007
    but for the love of god im not beeing able to find the correct spot for the sensor!
    @Crasher
    i have a 2008 Passat 2.0 TDI 170 CV BMR Motor!
    Thanks in Advance guys !
  2. Re: G42 Sensor Help
    1840 Post(s)
    The G42 is combined with the charge air pressure sensor G31 in the boost pressure sensor mounted in the boost pipe from the intercooler outlet hose and to the throttle body hose, part number 038 906 051 C
    1 1 0
  3. Re: G42 Sensor Help
    Aug 2021
    Portugal
    thanks alot Crasher , i will try to find it and unplug it and check if i have any reading in the VCDS !
  4. Re: G42 Sensor Help
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    Quote Originally Posted by Lysergicpt View Post
    It's at the front in the big intercooler hose that goes across from the hard metal pipe section that is on top of the gearbox to the intake. Not easy to see as it is on the back side of the pipe near one of the bends.
    Mad Mitch
    1 1 0
  5. Re: G42 Sensor Help
    Aug 2021
    Portugal
    @DMitch16 @Crasher
    Well first of all you need to know im just a rookie in this things , allthought i really like it , but im really having a hard time to find the Sensor can one of you guys ? point me in the right direction ?
    Its supposed to be in this area right ?
  6. Re: G42 Sensor Help
    Aug 2021
    Portugal
    Is it this little guy hidden over there ?
    thank you!
  7. Re: G42 Sensor Help
    Jan 2012
    10 Post(s)
    87 Post(s)
    thank you!
    No that's the 2nd coolant temperature sensor. Those pipes are coolant pipes not boost pipes. You need to trace backwards from the intake manifold pipe (large diameter rubber and plastic piping) and it should be right at the front, almost central but on the inner side of the pipe slightly masked from view below and not that easy to see from above hence stating its a tricky little fella to locate.
    Mad Mitch
    1 1 0
  8. Re: G42 Sensor Help
    1840 Post(s)
    As Mitch says, you need it up in the air.
    1 1 0
  9. Re: G42 Sensor Help
    Aug 2021
    Portugal
    ok guys , thank you i will get it up ! thanks alot
  10. Re: G42 Sensor Help
    Aug 2021
    Portugal
    @Crasher @DMitch16
    Thanks guys , its actually fairly easy to find from the bottom !
    An unrelated question for you guys , my Passat fold the mirror's via the mirror control button in the Driver Door , but my question is ! can i with VCDS make it fold the mirror's when i lock the car in the key fob and unfold when unlocked?
    Thanks !!!
  1. Replies: 9
    Last Post: 29-10-2020, 03:36 PM
  2. Replies: 0
    Last Post: 09-06-2020, 07:49 PM
  3. Camshaft position sensor / sender (G40 Hall sensor) replacement Audi A6 2.0 BRE
    By Strath44 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-05-2016, 02:26 PM
  4. Question Bora - Engine judder when driving - MAF sensor, temp. sensor or ABS fault??
    By Christo3000 in forum Bora - 1998 - 2005
    Last Post: 20-06-2011, 05:29 PM
  5. Replies: 3
    Last Post: 26-05-2011, 12:07 PM
