Thread: Is it normal? - 1.5 TSI revs up to 1300 rpm after staring
  1. Question Is it normal? - 1.5 TSI revs up to 1300 rpm after staring
    Aug 2021
    Uk
    Hi, I have little experience with petrol engines ...and wondering if this is normal...
    When the manual 1.5 TSI (130) is started it immediately jumps to 1200-1300 rpms, sometimes goes up and down a bit a few times before gradually going down and finally settling down around 800-900 rpms. It takes over a minute before these stable idle revs are reached.
    It is happening with both the cold engine or after a break of longer than 10 -20 min. All in warm weather, 20+ C outside.
    When off and on but for only a few minutes it then starts smoothly at low revs of 800-900.
    Any opinions?
    Cheers!
    (1.5 TSI 130 bhp, Sep20 build, filled up w/ E10)
  2. Re: Is it normal? - 1.5 TSI revs up to 1300 rpm after staring
    Aug 2008
    finland
    My 150hp eTSI DSG do it also at cold start. But it will slows down quickly.
  3. Re: Is it normal? - 1.5 TSI revs up to 1300 rpm after staring
    1837 Post(s)
    It is part of the catalyst fast light off strategy but something is amiss such as a dirty or misaligned throttle body, you need a code read first and the possibly the TB being cleaned and reset to the ECU.
  1. Replies: 0
    Last Post: 24-07-2020, 09:38 PM
  2. Please Help Between 1000 and 2000 revs, revs rise by about 100 revs every few seconds. Lumpy acceleration.
    By ricktherazor in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-05-2011, 08:53 AM
  3. Undecided mk2 1300(88)
    By Strutt in forum Golf MK2 - 1984 - 1992
    Last Post: 07-03-2008, 09:01 PM
  4. Mk2 1300 Worn Carb?
    By purplemk2 in forum New Member Introductions
    Last Post: 08-05-2007, 09:43 AM
  5. Mk2 1300 Worn Carb?
    By purplemk2 in forum The Classic VW's
    Last Post: 07-05-2007, 10:22 AM
