Thread: Audi A3 2.0 TDI 170 BMN Missfire
  1. Audi A3 2.0 TDI 170 BMN Missfire
    Aug 2021
    Bristol
    Hi, I’ve had this problem with my car which has been getting progressively worse as time goes on. Under load it missfires quite badly however it doesn’t throw a code up on vcds. The injector figures all look good and there’s no stutter or judder on idle. The previous owner deleted the dpf and remapped the car, which I am now starting to think it could be a dodgy map. I have swapped the tandem pump, changed the fuel filter and swapped the injectors out from another car with new o-rings and bolts and still has made no difference. If one of the new second hand injectors had an issue I’ve heard they usually throw up a code, so I think this is unlikely. I’ve also swapped the injector loom out and this has made no difference. Any help would be greatly appreciated.
    cheers.
  2. Re: Audi A3 2.0 TDI 170 BMN Missfire
    Near Blackpool
    48 Post(s)
    Ditch the map imho.
  3. Re: Audi A3 2.0 TDI 170 BMN Missfire
    Aug 2021
    Bristol
    Yeah I think that’s going to be the next step. I recorded map specified and map actual earlier under full load and it’s demanding and producing 2600 mbar of boost (2.6 bar / 37 psi) which seems way too much. I believe stock is supposed to be around 21 psi. No idea if it’s had a bigger turbo fitted, but that pressure seems far to high for a stock pd turbo.
  4. Re: Audi A3 2.0 TDI 170 BMN Missfire
    Near Blackpool
    48 Post(s)
    Sounds a lot, never been a fan of remapping stuff, never runs perfect and puts too much stress on things as people get carried away.
  5. Re: Audi A3 2.0 TDI 170 BMN Missfire
    134 Post(s)
    2012 Post(s)
    I don't understand how people get MOT passes on these cars, I can smell a de DPF'd BMN half a mile away... makes your eyes water.
  1. Audi A4 - Missfire issue
    By Mrtwiggy in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 17-04-2018, 03:42 PM
  2. Audi A6 2.8 auto hesitation/missfire
    By robbyallroad in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-05-2013, 04:58 PM
  3. Please Help Audi A4 Avant missfire, bad petrol?
    By pauldelaf in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-07-2011, 02:44 PM
  4. Audi 80 1.9tdi - Missfire/Engine Cut
    By darkartist in forum 80 - 90
    Last Post: 01-09-2008, 08:51 AM
  5. Audi 80 1.9tdi Engine missfire/cut out
    Last Post: 08-07-2007, 10:53 PM
