Thread: Best disassembly on clutch t4 man pet 97
  1. Best disassembly on clutch t4 man pet 97
    Nov 2014
    Tasmania
    It seems not alot is available on the subject just about anywhere, I have the stage of un-repair of squeeling bearings and the mech says its going going gone.
    I need to understand exactly the order of components to take off. Because the assembly slides out exactly, the distance it does would help to know and decide, on droping the engine and wish bone bolts and all the surrounding bolts.etc etc.
    retightening torque settings would help too.
  2. Re: Best disassembly on clutch t4 man pet 97
    Nov 2014
    Tasmania
    I've found a manual with most information, but will I need special tools for the job.
  3. Re: Best disassembly on clutch t4 man pet 97
    1837 Post(s)
    They are a bit evil to get out as you have to support and slide the engine over to the vans right to make room, all the tools you need a pretty much general hand tools.
  4. Re: Best disassembly on clutch t4 man pet 97
    Nov 2014
    Tasmania
    Well thats lucky, and its looks more like a bitch thats evil and i cant get that out of my head.
    Some guy has dismantled the whole left wheel assembly etc and confused the whole thing in videos.
    Starting this tomorrow until clutch's arrived then it hits the fan.
    Speaking of which, the drive shaft is disconnected at the wheel end or the bolts in engine?
  5. Re: Best disassembly on clutch t4 man pet 97
    Nov 2014
    Tasmania
    Ok it's in, vwk 7581 between 215 and 228mm ,recommended but honestly don't know......
  6. Re: Best disassembly on clutch t4 man pet 97
    Nov 2014
    Tasmania
    This special tool vw207c is to get the fly wheel off, can I adapt something? Also how much sub frame can stay on, the book says a lot off but time is difficult.
    IMPORTANT, how far does one pull the transmission before it is off, the reason is can I do it with less dropped engine...
  7. Re: Best disassembly on clutch t4 man pet 97
    Nov 2014
    Tasmania
    I have to pull out, lucky I checked before dropping the engine, tool 207c is hard to get.
    Job ends.
  1. Please Help Audi A3 2.0TDi hydraulic clutch - free play (top of clutch)
    By RavP in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 04-01-2018, 03:13 AM
  2. Worsening Mechanical Noise from Clutch Housing When Depressing Clutch Pedal.
    By uncleron in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 21-07-2013, 08:37 PM
  3. Replies: 5
    Last Post: 08-04-2013, 09:23 PM
  4. Please Help Replaced flywheel and clutch kit......but still makes that clunk noise from the clutch :(
    By Zeb in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-06-2011, 05:04 PM
  5. New clutch judders - faulty clutch fitting or fly wheel?
    By srana in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-10-2007, 09:31 AM
