Thread: BAG Engine Underpowered - Stuttering / Dithering / Misfire - What to log on VCDS?
Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. BAG Engine Underpowered - Stuttering / Dithering / Misfire - What to log on VCDS?
    Jul 2018
    Birmingham, West Midlands
    8 Post(s)
    After getting the oil leak sorted on my BAG engine (turned out to have a stripped thread on one of the bolts for the timing chain cover) the car has started to stutter when driving along at between 30-50mph.
    You can feel the engine almost slightly cough or misifre.....
    I've not detected a misifre on VCDS using the measuring blocks.
    I've also got no error codes to help with diagnose the issue.....unless it is a mechanical issue.....like the timing being ever so slightly out perhaps?
    I did use all the proper tools for the timing chain job and the car was running sweet before sorting the stripped thread on the engine block for the timing chain cover.
    What should I be logging on VCDS to help me find out the issue?
    I was thinking I need to look at fuel pressures, RPM, EGR? But I haven't got much of an idea in fairness.
    Could this issue be related to a bad low pressure fuel pump (LPFP) or high pressure fuel pump (HPFP)......cam follower / bucket was changed a while back but when doing the engine
    swap it looked in good condition when I took it out. The relay for the LPFP was also replaced a year or 2 ago with a genuine VW part.
    The injectors were also all ultrasonically cleaned using an ASNU machine so not suspecting a bad injector.
    Perhaps its an air leak, or maybe a bad spark plug or coil pack but not getting any codes for them?
    Any help would be appreciated.
  2. Re: BAG Engine Underpowered - Stuttering / Dithering / Misfire - What to log on VCDS?
    132 Post(s)
    1979 Post(s)
    To me that is running lean, I would check the lambda correction values. A quick test is to turn off the Lambda control in Basic Settings 099 and see if the hesitation clears but not for too long as it can upset the cat. By the way, according to VAG cleaning FSI injectors damages them and makes then run... lean.
  3. Re: BAG Engine Underpowered - Stuttering / Dithering / Misfire - What to log on VCDS?
    Jul 2018
    8 Post(s)
    Could removing the timing chain and have timing off make the engine run slightly lean?
    Seems very strange as it was running perfectly well before the thread reapir....no stuttering or "lean" condition.....
    Running lean can also be caused by air leaks too right? Should I be looking for something like that or not?
    What MVB blocks in VCDS do I need to look at......is this what they call "fuel trims" or is lambda correction values something else?
    I remember reading something about them and the value should change from +VE and -VE.....but I could getting confused here.
    I am just trying to pin point what else I might have done during the thread reapair on the block that may have caused this.....
    I did release the engine from its mounts and used an engine support to lower the engine to get enough access so I had line of sight with a drill.....
    Just thinking whether this may have pulled on the wiring harness or something?
    Ah bugger so I may ruined the injectors by cleaning them? They did seem fine after having them cleaned and didn't notice any issues....
    After doing the lambda check would it be worth changing out the injectors for some other ones? (Obviously replacing the teflon seals and o rings with new ones too).
    Never done the 099 basic setting.....what will happen exactly? and how long is too long? Can I drive a couple of miles, 10 miles? Just don't want to cause damage to the cat.......(the downpipe cat was
    replaced with a non genuine part / aftermarket as they were far too expensive....
  4. Re: BAG Engine Underpowered - Stuttering / Dithering / Misfire - What to log on VCDS?
    Jul 2018
    8 Post(s)
    Fault codes scan from VCDS.....
    Code:
    Friday,13,August,2021,18:06:20:33544
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 21.3.0.0 (x64)
    Data version: 20210226 DS325.0
    www.Ross-Tech.com
    VIN: WVWZZZ1KZ4W096975   License Plate:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
    VIN: WVWZZZ1KZ4W096975   Mileage: 367880km-228590miles
    08-Auto HVAC -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    56-Radio -- Status: OK 0000
    Address 01: Engine        Labels: 03C-906-056-BAG.lbl
       Part No SW: 03C 906 056 BA    HW: Hardware No
       Component: MED9.5.10       G00 5697
       Revision: 00000000    Serial number: VWZ7Z0D9331576
       Coding: 0000072
       Shop #: WSC 01279 785 00200
       VCID: 63C1C201A2D6B093BE-8036
    1 Fault Found:
    18729 - Oxygen (Lambda) Sensor B1 S1
                P2297 - 001 - Control Range Exceeded during Deceleration
    Readiness: 0000 0000
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
       Part No: 1K0 907 379 K
       Component: ESP FRONT MK60      0103
       Coding: 0019073
       VCID: 3A7F5F6575DC915BCD-806E
    No fault code found.
    Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
       Part No: 1K0 820 047 CB
       Component: Climatic PQ35   080 0201
       Shop #: WSC 00000 000 00000
       VCID: 66C7DB1551E4C5BB59-8032
    1 Fault Found:
    00229 - Refrigerant Pressure
                002 - Lower Limit Exceeded
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-M.lbl
       Part No SW: 1K0 937 049 K    HW: 1K0 937 049 K*
       Component: Bordnetz-SG 1.0 H30 0701
       Revision: 00030000    Serial number: 00000000514812
       Coding: E48D0F0600041800001400001400000000
       VCID: 3779465146CE8C3332-8062
       Subsystem 1 - Part No: 1K2 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer VW350  012  0401
       Coding: 00065493
       Shop #: WSC 00000
       Subsystem 2 - Part No: 1K0 955 559 K  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 002  0505
       Coding: 00217125
       Shop #: WSC 00000
    1 Fault Found:
    01049 - Supply Voltage Term 50
                006 - Short to Plus - Intermittent
    Address 15: Airbags        Labels: 1K0-909-605.lbl
       Part No SW: 1K0 909 605 A    HW: 1K0 909 605 A
       Component: 0M AIRBAG VW8   022 0500
       Revision: 04022000    Serial number: 0033FD08P0VC
       Coding: 0012365
       Shop #: WSC 01268 785 00200
       VCID: 2A5F6F25857C21DBBD-807E
       Subsystem 1 - Serial number: 6332MSME5D7E1002
       Subsystem 2 - Serial number: 6342MSME57340A02
       Subsystem 3 - Serial number: 6351HSME43485801
       Subsystem 4 - Serial number: 6361HSME5D0F5901
    Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
       Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
       Component: Lenksäulenmodul 012 0030
       Coding: 0000022
       VCID: 306B7D4DA3A05B0B73-8064
    Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
       Part No: 1K0 920 950 K
       Component: KOMBIINSTRUMENT VDD 3554
       Coding: 0000401
       Shop #: WSC 00218 210 03908
    Address 19: CAN Gateway        Labels:. 1K0-907-530-V1.clb
       Part No SW: 1K0 907 530 C    HW: 1K0 907 951
       Component: Gateway         H08 0080
       Revision: 08          Serial number: 2100104128EF35
       Coding: 3D0F0340070003
       VCID: 27599611966E1CB3A2-8072
    Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
       Component: IMMO                3554
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
       Part No: 1K0 959 701 E
       Component: Tuersteuergeraet 09 0116
       Coding: 0000052
    Address 44: Steering Assist        Labels: 1Kx-909-144-G2V1.clb
       Part No: 1K2 909 144 E
       Component: EPS_ZFLS Kl.1       1202
       VCID: 2E576335B9944DFB61-807A
    Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 BL
       Component: 01 KSG              0301
       Coding: 81E802087F2D8505485BC61000
       Shop #: WSC 00218 210 08203
       VCID: 7BF19A613A66685396-802E
       Subsystem 1 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HORN H05 1501
       Subsystem 2 - Part No: 1K0 907 719
       Component: Neigungssensor  003 0003
       Subsystem 3 - Part No: 1K0 951 177
       Component: Innenraumueberw.004 0101
    1 Fault Found:
    01134 - Alarm Horn (H12)
                004 - No Signal/Communication
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
       Part No: 1K0 959 702 E
       Coding: 0000052
       VCID: 316D7849A8AA52037C-8064
    Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
       Part No: 1K0 035 186 J
       Component: Radio BNO           0016
       Coding: 0040400
       VCID: 2D556439B49236E358-8078
    End-------------------------(Elapsed Time: 01:36)--------------------------
  5. Re: BAG Engine Underpowered - Stuttering / Dithering / Misfire - What to log on VCDS?
    132 Post(s)
    1979 Post(s)
    Do a learnt values clear in Adaptation do this three times. Then go into Basic Settings 04 and do a throttle body set and then an EGR set, take the car for a run and do an overrun EGR test, check the Readiness code shows the EGR is OK. Also do a manifold adaption but I suspect you have a small air leak.
  6. Re: BAG Engine Underpowered - Stuttering / Dithering / Misfire - What to log on VCDS?
    Jul 2018
    8 Post(s)
    Thanks Crasher appreciate the help.
    how do I perform each of these operations?
    learnt clear values clear adaptations - three times?
    throttle body reset (this is in basic settings from memory in engine module?)
    egr set (engine module basic settings?)
    not heard of an egr overrun test??
    manufold adaptation too not sure if this is in basic settings on Engine module?
    how is readiness checked? In MVB?
    if you can provide instructions that would be greatly appreciated.
    how do I identify a trace the air leak? Where could that be coming from? Intake or exhaust side? Do I need to do a smoke test or spray with brake cleaner and listen to exhaust nite?
    i did perform an egr adaptation and throttle body adapatation yesterday but think car is still spluttering?
    they only thing I can think of is that I’ve used a different manifold to cat exhaust stud as it sheared off when removing the Downpipe. Perhaps there is a leak before the oxygen sensor (bank 1 sensor 1).
  7. Re: BAG Engine Underpowered - Stuttering / Dithering / Misfire - What to log on VCDS?
    Jul 2018
    8 Post(s)
    Was also thinking that potentially the change from E5 to E10 might be having a influence here too? But don’t think this is live until September? But I have seen in a few petrol stations that the labelling has changed already to E10.....could this be causing my issue?
    I think my engine is impacted by this fuel change and will damage the seals on the injectors due to the higher ethanol content?
    would it be worth pulling the injectors and renewing the seals? Or replacing injectors? I do have a spare set that haven’t been cleaned with ultrasonics.
  8. Re: BAG Engine Underpowered - Stuttering / Dithering / Misfire - What to log on VCDS?
    132 Post(s)
    1979 Post(s)
    With your engine being an early BAG, VAG have stated this engine is not suitable for use with E10, run it on the “protection” grade but to be honest these have always need 99RON since they were introduced… it is just that VAG UK hopped they would get away with it and roughly, they did.
  9. Re: BAG Engine Underpowered - Stuttering / Dithering / Misfire - What to log on VCDS?
    Jul 2018
    8 Post(s)
    No worries I shall run with the RON99 / V Power Shell and see if that makes a difference.
    How do I find the small air leak?
    Tried the adaptations above but still getting the stutter (no misifre detected according to VCDS though.....)
  10. Re: BAG Engine Underpowered - Stuttering / Dithering / Misfire - What to log on VCDS?
    132 Post(s)
    1979 Post(s)
    A smoke machine is the usual way if you can't hear it.
  1. Replies: 0
    Last Post: 30-01-2021, 04:30 PM
  2. Replies: 4
    Last Post: 24-02-2016, 09:22 PM
  3. Stuttering engine
    By Tallulah in forum Golf MK4 - 1999 - 2004
    Last Post: 07-03-2014, 03:10 PM
  4. Engine Stuttering / Hesitation
    By stewhp in forum Golf MK3 - 1993 - 1999
    Last Post: 11-03-2009, 01:51 AM
  5. Polo engine stuttering
    By chrisdevine in forum Polo - Derby - Lupo - Fox
    Last Post: 30-11-2006, 12:47 AM
