Thread: BAG Engine Underpowered - Stuttering / Dithering / Misfire - What to log on VCDS?
Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
  1. Re: BAG Engine Underpowered - Stuttering / Dithering / Misfire - What to log on VCDS?
    #21
    132 Post(s)
    1979 Post(s)
    Get a compression test done.
  2. Re: BAG Engine Underpowered - Stuttering / Dithering / Misfire - What to log on VCDS?
    #22
    Jul 2018
    Birmingham, West Midlands
    8 Post(s)
    Cylinder 1 150psi 10bar
    Cylinder 2 150psi 10bar
    Cylinder 3 150psi 10bar
    Cylinder 4 137.5/140psi 9.5bar
  3. Re: BAG Engine Underpowered - Stuttering / Dithering / Misfire - What to log on VCDS?
    #23
    132 Post(s)
    1979 Post(s)
    Good compression on number 2 with a misfire suggests plug/coil pack; they don't like being removed.
  4. Re: BAG Engine Underpowered - Stuttering / Dithering / Misfire - What to log on VCDS?
    #24
    Jul 2018
    8 Post(s)
    Ok thanks for the advice.
    So you recommend replacing all coils and plugs?
    Why does removing the coil packs damage them?
    We did find an air leak / split hose on the vacuum line to the solenoid and intake manifold for the intake runner flaps....
    Replaced with a new hose but hasn’t made a difference for the misfire.
    The misfire did spread to other cylinders too...have detected it across all
    of them now but it is quite sporadic.
  5. Re: BAG Engine Underpowered - Stuttering / Dithering / Misfire - What to log on VCDS?
    #25
    Jul 2018
    8 Post(s)
    What brand of coil pack should I use? OEM or BOSCH? Or something else?
    is the latest revision 036 905 715 F
  6. Re: BAG Engine Underpowered - Stuttering / Dithering / Misfire - What to log on VCDS?
    #26
    132 Post(s)
    1979 Post(s)
    Personally I would fit Bosch coils and plugs, the latest number for the coils genuine is 036 905 715 H which is a Bosch 0 986 221 023 and the plugs are FGR 6 HQE 0
  7. Re: BAG Engine Underpowered - Stuttering / Dithering / Misfire - What to log on VCDS?
    #27
    Jul 2018
    8 Post(s)
    Yep got the Bosch coils as above (0986 221 023) but couldn’t get hold of the Bosch sparks plugs so went for NGK ZFR6S-Q
  1. Replies: 0
    Last Post: 30-01-2021, 04:30 PM
  2. Replies: 4
    Last Post: 24-02-2016, 09:22 PM
  3. Stuttering engine
    By Tallulah in forum Golf MK4 - 1999 - 2004
    Last Post: 07-03-2014, 03:10 PM
  4. Engine Stuttering / Hesitation
    By stewhp in forum Golf MK3 - 1993 - 1999
    Last Post: 11-03-2009, 01:51 AM
  5. Polo engine stuttering
    By chrisdevine in forum Polo - Derby - Lupo - Fox
    Last Post: 30-11-2006, 12:47 AM
