Thread: Dreadful Timing Chain Tensioner or Something Else
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: Dreadful Timing Chain Tensioner or Something Else
    Oct 2010
    leeds
    From what I’ve gathered these are common issues among these engines of certain model years. I really hope that it wasn’t anything serious but I’ll find out what’s what tomorrow. Not holding my breath on it to be cheap.
  2. Re: Dreadful Timing Chain Tensioner or Something Else
    Oct 2010
    leeds
    So it seems that the rattle from engine is due to camshafts and my mechanic mentioned to me to replace all 4. Not a cheap job by any stretch of imagination so he asked me t contact Audi UK to see if they will contribute as good will given that I’ve had this and 3 other cars from them but given that mine is out of warranty and isn’t maintained by them I doubt there’ll be any help from them. I may just have to foot the bill to get the cams replaced.
  3. Re: Dreadful Timing Chain Tensioner or Something Else
    1837 Post(s)
    That’s £2150 in cams alone… The roller rockers have been upgraded twice and are now, 059 109 417 S at £14.98 each
  4. Re: Dreadful Timing Chain Tensioner or Something Else
    Oct 2010
    leeds
    Yep, as I said it won't be cheap at all. Which is why I'm gonna try my luck with Audi. Not much hope but let's see what they say.
  5. Re: Dreadful Timing Chain Tensioner or Something Else
    Mar 2010
    Derry ireland
    60 Post(s)
    Y0ur oil pressure on this vehicle has to be checked out first & foremost. Your cams runs on a cushion of oil like all cam & crankshafts. If you go ahead and fit cams then find out you have a oil pressure system fault. Always air on the side of caution
  6. Re: Dreadful Timing Chain Tensioner or Something Else
    May 2013
    Nottingham
    This family of engines have electronically adjustable oil pump and oil pressure is signifficantly lowered in part load conditions to reduce engine load and emissions. We do have solution to bring it up it helps to prolong lifespan of camshafts and makes engine less noisy. Them engines are known for catastrophic failures due to reduced lubrication.
  7. Re: Dreadful Timing Chain Tensioner or Something Else
    #17
    Jan 2023
    Loughborough
    I know this it’s completely off topic but I have modified the Passat engine to work and run in a Audi A3 had to change a few things to get it to accept it but it is do able it’s now running good had a few Audi’s I just like to see what can be made of them and if anyone wants to know how to was changed to accept the engine I happy to show them just here haveing fun
  1. Audi A6 3.0 TDi 272 - Timing Chain Tensioner
    By gmcc12 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 15-08-2021, 05:58 PM
  2. 3.0 Tdi Timing Chain Tensioner
    By jouk in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-08-2014, 05:53 PM
  3. Alt 2.0 timing chain tensioner
    By candradh in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-05-2014, 07:46 PM
  4. s4 timing chain tensioner
    By charliebucket in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-03-2010, 03:54 PM
  5. Timing chain tensioner
    By NIgolf in forum Passat - Archive Topics
    Last Post: 20-03-2007, 07:10 AM
