Hi all,
any ideas what can cause the ACC error on the dashboard based off the below VCDS scan I have done? Where is the module/wiring for the ACC located? Thank you.
Address 01: Engine (J623-CRBC) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 DS HW: 04L 907 309 D
Component: R4 2,0L EDC H21 4941
Revision: 83H21---
Coding: 02190012034501082000
Shop #: WSC 22895 000 1048576
ASAM Dataset: EV_ECM20TDI01104L906021DS 002008
ROD: EV_ECM20TDI01104L906021DS_002_AU37.rod
VCID: 79F93334F80C2D4C45-802C
1 Fault Found:
17156 - Databus
U1123 00 [039] - Received Error Message
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 2
Mileage: 146208 km
Date: 2021.08.09
Time: 01:56:24
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 53 °C
Intake air temperature: 56 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 11.920 V
Unlearning counter according OBD: 40
Drivetrain coordinator: ACC fault status-Bits 0-7: 0
Drivetrain coordinator: brake fault status-Bits 0-7: 0
Drivetrain coordinator: brake function status-Bits 0-7: 0
Acceleration: 0.000 m/s²
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 AC HW: 5Q0 907 379 D
Component: ESC H75 0437
Revision: 00000000 Serial number:
Coding: 10F18AA220200A730379060201C92908510450C0608094F3F4 79500405
ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
ROD: EV_Brake1UDSContiMK100IPB_008.rod
VCID: 7DF12724EC24116C69-8028
No fault code found.
Address 08: Auto HVAC (E87) Labels:| 8V0-820-043.clb
Part No SW: 8V0 820 043 A HW: 8V0 820 043 A
Component: AC Automat H11 0031
Revision: 20017000 Serial number: 00000000008602
Coding: 00100104002000011000000000001100
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_AirCondiFrontVaAU37X 008016
ROD: EV_AirCondiFrontVaAU37X_008.rod
VCID: 306FCE106BF62C04B2-8064
Humidity sensor: exterior:
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: DA188346000000000001
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 G HW: 5Q0 937 084 G
Component: BCM MQBAB H H10 0083
Serial number: 33051222100068
Coding: 07000B46C28122FD03044000B31C0728001C00000000000000 0000000000
ASAM Dataset: EV_BCMCONTI 009001
ROD: EV_BCMCONTI_009.rod
VCID: 3C77EA20B7BED8641E-8068
Wiper motor control module:
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 120617 041 0570
Serial number: 120718054504
Coding: 0A47F7
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 20505673
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 L HW: 8V0 941 531 L
Component: E1 - LDS MQB H05 0032
Serial number: 20 07 2012 00000060
Anti-theft alarm system sensor:
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0313
Serial number: 000000000ZY121861HP6
Alarm horn:
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000010011898
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 A HW: 5Q0 919 294 A
Component: PARKHILFE 8K 002 0021
Revision: -------- Serial number: 94231219506215
Coding: 0070050041
ASAM Dataset: EV_EPHVA18AU3700000 002015
ROD: EV_EPHVA18AU3700000_002_VW37.rod
VCID: 3979F334B88CED4C05-806C
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-567.clb
Part No SW: 5Q0 907 567 H HW: 5Q0 907 567 F
Component: ACC3 H07 0096
Serial number: 06081276110151
Coding: 00200701FE0309
Shop #: WSC 55297 001 1048576
ASAM Dataset: EV_ACCBoschMQB 001023
ROD: EV_ACCBoschMQB_AU37.rod
VCID: 408F9ED0DB56BC8442-8014
2 Faults Found:
1546 - Internal Control Module Memory Check Sum Error
B2000 04 [047] - Internal System Fault
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Control Module temperature: 10 °C
Voltage terminal 15: 12.0 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s²
1117 - Automatic Distance Control
B10E7 F0 [047] - Disconnected
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 205
Mileage: 146208 km
Date: 2021.08.09
Time: 01:56:24
Control Module temperature: 32 °C
Voltage terminal 15: 11.7 V
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 L HW: 5Q0 959 655 L
Component: AirbagVW20 009 0349
Serial number: 003GER005XR$
Coding: 98CCC0000C0000005C5400CA00C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 499983F4E86C7DCC95-801C
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: ----------- HW: 480 000 808 12
Component: SideSensor_Df 001 0887
Serial number: 35767000000AA06DBB03
Coding: 2D2D2D
Front Passenger's Side Airbag Crash Sensor:
Subsystem 2 - Part No SW: ----------- HW: 480 000 808 12
Component: SideSensor_Pf 001 0887
Serial number: 35867000000B306DBB0+
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 3 - Part No SW: ----------- HW: 480 402 307 12
Component: SideSensor_Dr 001 6149
Serial number: 3516502B50B3DFC2329M
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 4 - Part No SW: ----------- HW: 480 402 307 12
Component: SideSensor_Pr 001 6149
Serial number: 3526502AF0C37664A2DP
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 5 - Part No SW: ----------- HW: 480 401 207 12
Component: FrontSensor_D 001 6149
Serial number: 3556502A70BE4C3120AE
Coding: 2D2D2D
Driver's side crash data pedestrian protection:
Subsystem 6 - Part No SW: ----------- HW: 480 402 307 12
Component: PedP_Sensor_D 001 6149
Serial number: 2286502A70C37664C06C
Coding: 2D2D2D
Passenger's side crash data pedestrian protection:
Subsystem 7 - Part No SW: ----------- HW: 480 402 307 12
Component: PedP_Sensor_P 001 6149
Serial number: 2296502A70C37660421+
Coding: 2D2D2D
Center pedestrian protection crash sensor:
Subsystem 8 - Part No SW: ----------- HW: 480 402 307 12
Component: PedP_Sensor_C 001 6149
Serial number: 2306502A30C37663109Z
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels:. 5Q0-953-549.clb
Part No SW: 8V0 953 521 AK HW: 5Q0 953 549 A
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 020812000300MB
Coding: EC08
ASAM Dataset: EV_SMLSKLOMQB 009001
ROD: EV_SMLSKLOMQB_010_VW37.rod
VCID: 030551DC8AC0679C1F-8056
No ASAM data for: "EV_SMLSKLOMQB" (AU37)
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 8V0 920 970 K HW: 8V0 920 970 K
Component: KOMBI H22 0490
Coding: 278401006E8446000100E800000000
ASAM Dataset: EV_DashBoardVDDMQBAB 008026
ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
VCID: 448792C0CF4EA0A466-8010
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 C HW: 5Q0 907 530 C
Component: GW MQB High 109 1072
Revision: -------- Serial number: 0000069329
Coding: 030100F40B0876005B000258080B0000000100000000000000 0000000000
ASAM Dataset: EV_GatewLear 005010
ROD: EV_GatewLear_005.rod
VCID: 3169CB1460FC250CBD-8064
Generator:
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Component: E221 - MFL H02 0014
Serial number: 07 08 2012 D0099511
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 4388328001
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 A HW: 5Q0 959 593
Component: TSG FS H12 0006
Serial number: 26071200010037
Coding: 005D0E204001040100001003
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 3F8D9D2CA6A8C37C3B-806A
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 K
Component: EPS_MQB_ZFLS 119 1021
Coding: 91
ASAM Dataset: EV_SteerAssisMQB 008022
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D71E724ACA4D16C29-8068
Address 47: Sound System (J525) Labels:* None
Part No SW: 8V0 035 465 D HW: 8V0 035 465
Component: MIBAMP1ALPINE H11 0420
Serial number: AUZ8ZAC09001G5%
Coding: 01030300AAAA2AAA01
ASAM Dataset: EV_AMPMst16C1ALPI 004024
ROD: EV_AMPMst16C1ALPI_004_AU37.rod
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 A HW: 5Q0 959 592
Component: TSG BFS H12 0006
Serial number: 25071200010513
Coding: 005D06204001040100001003
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 3E73E028A1A2CA7430-806A
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0070
Revision: -------- Serial number: --------------
Coding: 019E000001000000
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB.rod
VCID: 75E13F04D414492C21-8020
Address 5F: Information Electr. (J794) Labels:* None
Part No SW: 8V0 035 019 HW: 8V0 035 043
Component: MU-H-N-EU H40 0404
Serial number: A039H0C7509085
Coding: 017300010000000021110002000A00002F000127010001009E
Shop #: WSC 64520 001 1048576
ASAM Dataset: EV_MUHig6C3HBAS 001040
ROD: EV_MUHig6C3HBAS_VW48.rod
VCID: 70EF0E10AB766C04F2-8024
Data carrier:
Subsystem 1 - Part No SW: V03 959 800 E HW: -----------
Component: ECE 2012/13 --- 0028
Serial number: --------------------
Multimedia System 1:
Subsystem 2 - Part No SW: 8V0 919 604 A HW: 8V0 919 604 A
Component: DU High H47 0014
Serial number: AUZ8Z9C07001UX
Multimedia system control head:
Subsystem 3 - Part No SW: 8V0 919 614 R HW: 8V0 919 614 D
Component: ControlUnit_H H64 0766
Serial number: C1000004061200010136
Compact disc data bank:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote --- 1007
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 5Q0-980-653.clb
Part No SW: 5Q0 980 653 C HW: 5Q0 980 653
Component: MQB_MFK H03 0032
Serial number: 00000004560
Coding: 0101010001010303000300000100010100
ASAM Dataset: EV_MFKBoschAU370 001001
ROD: EV_MFKBoschAU370.rod
VCID: 387FF6308386F444FA-806C
