Hi Guys,
Been struggling with this issue for a few days, hoping I may get some pointers.
Issues:
  1. Noticed that both my rear doors were locked, had to unlock from the inside and they no longer lock.
  2. Both rear windows failed at the same time, cannot be operated from the Drivers console or on the windows themselves.
  3. Rear Windows do not operate on the key fob either, (front windows OK)
I've check fuses to the side of the drivers wheel as well as the ones under the bonnet. I dug out my VCDS tool and there are alot of errors. Is this likely to be a wiring issue or a failure of the CCM
Sunday,08,August,2021,19:50:39:39744
VCDS Version: 21.3.0.0 (x64)
Data version: 20210226 DS325.0
Ross-Tech: Home
Chassis Type: 3C-VW46 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 4F 52 53 56 61 62 72
VIN: WVWZZZ3CZBE335830
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 FS HW: 03L 907 425 C
Component: R4 1.6l TDI H43 9979
Revision: --H43--- Serial number: 00000000000000
Coding: 00194016030501080000
Shop #: WSC 00015 115 00000
ASAM Dataset: EV_ECM16TDI02103L906023FS 003015
ROD: EV_ECM16TDI02103L906023FS_003.rod
VCID: 7CF02FB2F770276B9F-8028
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 M HW: 3AA 614 109 M
Component: J104 C2 450M V419 0005
Revision: --H07--- Serial number: 00000003620468
Coding: 0002983
Shop #: WSC 05311 000 00000
VCID: 377AF09E46D6C43332-8062
Address 08: Auto HVAC (J255) Labels:. 5K0-907-044.clb
Part No SW: 5K0 907 044 DT HW: 5K0 907 044 DT
Component: Climatronic H17 1010
Revision: 00003001
Coding: 0000000003
Shop #: WSC 00015 115 08193
ASAM Dataset: EV_Lcimatronic A01010
ROD: N/A
VCID: 00085B429B98438BC3-8054
No ASAM data for: "EV_Lcimatronic" (VW36 *)
2 Faults Found
13701520 - ROD - Unknown Error Code
- 00 [009]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 25
Mileage: 176386 km
Date: 2120.14.04
Time: 00:30:26
13701536 - ROD - Unknown Error Code
- 00 [009]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 25
Mileage: 176386 km
Date: 2120.14.04
Time: 00:30:26
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 3AA 937 087 HW: 3AA 937 087
Component: BCM PQ47 M 413 0452
Revision: BA413001
Coding: 000000000000000000180080100000E443010088424D816064 80C7200041
Shop #: WSC 05311 123 12345
VCID: 77FA309EC6560433F2-8022
Subsystem 1 - Part No: 3AC 955 119
Component: Wischer 10121 26 0612
Coding: 00B795
2 Faults Found
01333 - Door Control Module; Rear Left (J388)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 25
Mileage: 176385 km
Time Indication: 0
Date: 2056.14.04
Time: 00:25:35
Freeze Frame:
Term 15 On
Voltage: 10.80 V
OFF
ON
ON
ON
OFF
01334 - Door Control Module; Rear Right (J389)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 25
Mileage: 176385 km
Time Indication: 0
Date: 2056.14.04
Time: 00:25:35
Freeze Frame:
Term 15 On
Voltage: 10.80 V
OFF
ON
ON
ON
OFF
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 R HW: 5N0 959 655 R
Component: J234__102 VW10 HI 1918
Revision: 22014000 Serial number: 003K0PSK9EKA
Coding: 0012338
VCID: 4C90BF722F5057EB6F-8018
Subsystem 1 - Serial number: 6332MTS679833440
Subsystem 2 - Serial number: 6342MTS678313440
Subsystem 3 - Serial number: 6351HTS6KHNTL9KJ
Subsystem 4 - Serial number: 6361HTS63D20M9KJ
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
Part No SW: 3C9 953 501 BF HW: 5K0 953 569 S
Component: LENKS.MODUL 009 0136
Revision: FF010039 Serial number: 20101230201270
Coding: 1182050000
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS.rod
VCID: 6ED415FAB10C45FB21-803A
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TK6 H06 0022
Coding: E20000
Address 17: Instruments (J285) Labels: Redir Fail!
Part No SW: 3AA 920 970 A HW: 3AA 920 970 A
Component: KOMBI H20 0420
Coding: 461F00
Shop #: WSC 05314 115 00000
ASAM Dataset: EV_Okmbi_UDS_VDD_RM09 A04089
ROD: N/A
VCID: 316ECE8660B21A037C-8064
No ASAM data for: "EV_Okmbi_UDS_VDD_RM09" (VW46)
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 D HW: 1K0 907 951
Component: J533 Gateway H35 0614
Revision: H35 Serial number: 070111F2002577
Coding: 462007
Shop #: WSC 05314 000 00000
VCID: 316ECE8668B21A037C-8064
2 Faults Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 23
Mileage: 176343 km
Time Indication: 0
Date: 2055.14.28
Time: 20:53:37
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 23
Mileage: 176343 km
Time Indication: 0
Date: 2055.14.28
Time: 20:53:37
Address 25: Immobilizer Labels: Redir Fail!
Part No SW: 3AA 959 433 HW: 3AA 959 433
Component: IMMO 043 0399
Revision: 00043000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
VCID: 76E43D9A015C7D3BE9-8022
Subsystem 1 - Part No: 3C0 905 861 J
Component: ELV 029 0380
3C0905861J ELV 029 0380
Address 2E: Media Player 3
Cannot be reached
Address 42: Door Elect, Driver (J386) Labels:. 3C0-959-70X-GEN4.clb
Part No SW: 3AA 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0530
Revision: 13110009 Serial number: 0001949958
Coding: 0202B5
Shop #: WSC 05311 115 00000
ASAM Dataset: EV_TSGFP3Q5BRFVW46X A04001*
ROD: N/A
VCID: 74E00792DF206F2BD7-8020
No ASAM data for: "EV_TSGFP3Q5BRFVW46X" (VW46 *)
1 Fault Found
65538 - ROD - Unknown Error Code
- 00 [009]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 25
Mileage: 176385 km
Date: 2120.14.04
Time: 00:25:30
Address 44: Steering Assist
Cannot be reached
Address 46: Central Conv. Labels: Redir Fail!
Component: KSG PQ47 ELV 043 0631
Coding: 0191020052830E76300494157C085FCE107C01
Subsystem 1 - Part No: 1K8 951 605 A
Component: LIN BACKUP HORN H11 9004
Subsystem 2 - Part No: 3C0 951 171 C
Component: Neigungssensor 004 0611
Subsystem 3 - Part No: 3C0 951 171 C
Component: Innenraumueberw.004 0611
Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H35 0614
Coding: 00000008
VCID: 6FEA08FEBE064CF32A-803A
Subsystem 1 - Part No SW: 3AA 919 204 HW: 3AA 919 204
Component: Analoguhr 003 0003
Address 52: Door Elect, Pass. (J387) Labels:. 3C0-959-70X-GEN4.clb
Part No SW: 3AA 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0530
Revision: 15110009 Serial number: 0001956265
Coding: 0202B4
ASAM Dataset: EV_TSBGPQ35BRFVW46X A04001
ROD: N/A
VCID: 75E63A96D45A7623E0-8020
No ASAM data for: "EV_TSBGPQ35BRFVW46X" (VW46 *)
1 Fault Found
- 00 [009]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 25
Mileage: 176385 km
Date: 2120.14.04
Time: 00:25:30
Address 53: Parking Brake Labels: None
Part No SW: 3AA 907 801 E HW: 3AA 907 801 E
Component: J540 EPB4 VW-55183 0007
Revision: H18 Serial number: 00000000112409
Coding: 0022067
VCID: 3362C48E52AE28130E-8066
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 1K0 035 186 AA HW: 1K0 035 186 AA
Component: Radio RCD310 016 0049
Revision: 01000000 Serial number: VWZ1Z2K8190453
Coding: 0100040004
Shop #: WSC 01211 210 01254
VCID: 65C66AD66CFA86A350-8030
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H35 0614
Coding: 030B085A
VCID: 71EE0E86A8325A033C-8024
Subsystem 1 - Part No SW: 1K0 915 181 F HW: 1K0 915 181 A
Component: J367-BDM H07 0150
Serial number: 00000000009370352401
End-------------------------(Elapsed Time: 03:00)--------------------------
