Thread: Air conditioning has stopped working 1 fault code.
Results 1 to 10 of 11
  1. Air conditioning has stopped working 1 fault code.
    Feb 2013
    Uk
    38 Post(s)
    Hi all,
    My air con has stopped working , I have the 2 zone climate control. When I press the “AC” button it lights up as normal, but does not deliver cold air .
    Here is the Fault code, can anyone help with this, many thanks.
    1 Fault Found:
    0237 - Function Restricted due to Missing Message(5)
    U1111 00 [009] - -
    [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: C0000001
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 115
    Mileage: 243210 km
    Date: 2023.05.17
    Time 18.35.34
    Voltage terminal 30. 12.08 V
    Outside temperature 21.0 °C
    Engine RPM: 0 /min
  2. Re: Air conditioning has stopped working 1 fault code.
    131 Post(s)
    1976 Post(s)
    We need a full car scan using the latest interface as yours is not going to provide the necessary data such as time and date stamps with values.
  3. Re: Air conditioning has stopped working 1 fault code.
    Feb 2013
    Uk
    38 Post(s)
    Thanks crasher will post a scan today.
    I should have said the fault is there before you turn on air con or blower without using the A/C.
    ie turn on the ignition without engine running , run scan and the fault is there , then if you clear the fault it comes straight back.
  4. Re: Air conditioning has stopped working 1 fault code.
    Feb 2013
    Uk
    38 Post(s)
    Code:
    Saturday,20,May,2023,08:53:26:15671
    VCDS Version: 22.9.0.0 (x64)
    Data version: 20220830 DS341.0
    Ross-Tech: Home
    VIN: WAUZZZ4G6CN052908   License Plate:
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3B 42 44 46 52 53 55 56
              5F 62 6C 72
    VIN: WAUZZZ4G6CN052908   Mileage: 243214km-151126miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: Malfunction 0010
    3B-Sensor Elect. -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    6C-Back-up Cam. -- Status: Malfunction 0010
    Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
       Part No SW: 03L 906 018 LB    HW: 03L 906 018 JL
       Component: R4 2.0l TDI   H25 9978
       Revision: 45H25---    CVN: 1E5FEF43
       Coding: 0A034012242401080000
       Shop #: WSC 59152 001 1048576
       ASAM Dataset: EV_ECM20TDI01103L906018LB 003012
       ROD: EV_ECM20TDI01103L906018HA.rod
       VCID: 75E180C2D4FC012560-8020
       VINID: 9D196AAAA117193780142240208E6B514F
    No fault code found.
    Readiness: 0 0 0 0 1
    Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
       Part No SW: 4G0 927 155 T    HW: 0AW 927 156 K
       Component: 0AW 20TDI RdW H04 0005
       Revision: --H04---    Serial number: 0000000871 CVN: 00004B4A
       Coding: 000001
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_TCMVL381 A02430
       ROD: EV_TCMVL381.rod
       VCID: 3C7755E6B756906D5F-8068
    Address 03: ABS Brakes (J104)       Labels:. 4G0-907-379-V1.clb
       Part No SW: 4G0 907 379 F    HW: 4G0 907 379 F
       Component: ESP PREMIUM   H09 0250
       Revision: --------    Serial number: --------------
       Coding: 06A187016085E180DB00
       ASAM Dataset: EV_ESPPremiAU57X 004017
       ROD: EV_ESPPremiAU57X_004_AU57.rod
       VCID: 34677DC69F06582D97-8060
    Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
       Part No SW: 4H0 907 064 BP    HW: 4H0 907 064 BP
       Component: BCM2 2.0      H31 0330
       Revision: 00002001
       Coding: 05B82F06000000000000
       VCID: 78FF89F6CBEE7C4D7B-802C
       Subsystem 2 - Part No SW: 4H0 905 852 C    HW: 4H0 905 852 C
       Component: J764 ELV MLB  H39 0046
       Serial number: 2311000195339016
    Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
       Part No SW: 4G0 820 043 G    HW: 4G0 820 043 G
       Component: KLIMA 2 ZONEN H10 0062
       Serial number: 31081100040713
       Coding: 34310008A0
       ASAM Dataset: EV_AirCondiBasisUDS 002037
       ROD: EV_AirCondiBasisUDS_002.rod
       VCID: 23458E9A2AE8CF957E-8076
    1 Fault Found:
    0237 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 115
                        Mileage: 243214 km
                        Date: 2023.05.20
                        Time: 08:50:39
                        Voltage terminal 30: 11.54 V
                        Outside temperature: 13.0 °C
                        Engine RPM: 0 /min
    Address 09: Cent. Elect. (J519)       Labels:. 4H0-907-063-V1.clb
       Part No SW: 4H0 907 063 BE    HW: 4H0 907 063 E
       Component: BCM1 2.0      H12 0100
       Revision: 19012002    Serial number: 00000001043953
       Coding: 2608201151349FE00181008480001D0C4F9DC30827090101000004602500
       Shop #: WSC 02391 785 00200
       VCID: 6CD7A5A68FB6C0ED8F-8038
       Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS57X 110707  H35 0051
       Serial number:         110722003241
       Coding: 0045F7
       Subsystem 2 - Part No SW: 8K0 955 559     HW: 8K0 955 559   Labels: 8K0-955-559.CLB
       Component: RLS  H04 0003
       Serial number: 11664555
       Coding: 02512B
       Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
       Component: E1 - LDS  H07 0044
       Serial number: 07 09 2011  00000998
       Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
       Component: Humidity_Sens  H02 0002
       Serial number: CD0885C5000000000001
    Address 10: Park/Steer Assist (J446)       Labels:| 4H0-919-475-7X2.clb
       Part No SW: 4H0 919 475 N    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H07 0050
       Revision: 11001001    Serial number: 55901125100389
       Coding: 280306
       ASAM Dataset: EV_EPHVA18AU57X0000 002005
       ROD: EV_EPHVA18AU57X0000_002_AU57.rod
       VCID: 3D7158E2AC4C996568-8068
    Address 15: Airbags (J234)       Labels:* 4H0-959-655.clb
       Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
       Component: Airbag10.43   H40 0040
       Revision: --------    Serial number: 003JG00421DF
       Coding: 30323436313230303235554A305234473053
       ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
       ROD: EV_AirbaAU10BPAAU64X_VW51.rod
       VCID: 366347CE897A4A3DA9-8062
       Crash sensor for side airbag: driver side:
       Serial number: 3575HRB40530OPI250MB
       Front Passenger's Side Airbag Crash Sensor:
       Serial number: 3585HRB404V0OPI2AGID
       Rear Side Airbag Crash Sensor (on driver's side):
       Serial number: 3515JRB40610NS9OB0NS
       Passenger side rear thorax airbag crash sensor:
       Serial number: 3525JRB405V0MFP668O3
       Crash sensor for front airbag: driver side:
       Serial number: 3554VRB40650N49OJOUJ
       Crash sensor for front airbag: front passenger side:
       Serial number: 3564VRB40670N49OO15M
    Address 16: Steering wheel (J527)       Labels:. 4H0-953-568.clb
       Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
       Component: Lenks.Modul   H05 0201
       Revision: 00000000    Serial number: 20110915001273
       Coding: 000034
       VCID: 306F71D6631E640DF3-8064
       Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
       Component: E221 - MFL  H08 0009
    Address 17: Instruments (J285)       Labels:| 4H0-920-xxx-17.clb-SRI1
       Part No SW: 4G8 920 981 S    HW: 4G8 920 981 S
       Component: TDieGb        H71 0375
       Revision: 26181114    Serial number: 658110911592023
       Coding: 33A708000B012600010000
       ASAM Dataset: EV_RBD4K 004040
       ROD: EV_RBD4K_AU57.rod
       VCID: 43852E1ACAA8EF951E-8016
    Address 19: CAN Gateway (J533)       Labels:| 4H0-907-468.clb
       Part No SW: 4G0 907 468 E    HW: 4G0 907 468 A
       Component: J533--Gateway H08 0213
       Revision: --------    Serial number: 00000000249182
       Coding: 00CD074400
       GVL: FDA1E808DE62600100
       ASAM Dataset: EV_GatewUDS 001025
       ROD: EV_GatewUDS_AU57.rod
       VCID: 326B7BDE6512561D85-8066
       Battery Monitoring Control Module:
       Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
       Component: J367-BDM  H07 0140
       Serial number: 00000000005650306342
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 8K0 959 663     HW: 8K0 959 663
       Component: J532_DCDCStab  H17 0042
       Serial number: 11259002401021200181
    Address 36: Seat Mem. Drvr (J136)       Labels: None
       Part No SW: 4G8 959 760     HW: 4G8 959 760
       Component: MEM-FS        H03 0154
       Revision: AA000000    Serial number: 00000013292832
       Coding: 00783B420000B201000001010101102030303232203232
       VCID: 77FD8ACAC6F0733572-8022
    1 Fault Found:
    03725 - Control Module for Seat Belt Tensioner; Left Front
                004 - No Signal/Communication
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 115
                        Mileage: 243214 km
                        Time Indication: 0
                        Date: 2023.05.20
                        Time: 08:50:40
    Address 3B: Sensor Elect. (J849)       Labels: 4G0-907-637.clb
       Part No SW: 4G0 907 637     HW: 4G0 907 637
       Component: SARA 3D       H02 0004
       Revision: --------    Serial number: EJ1BPA3200J93U0
       Shop #: WSC 00000 000 00000
       ASAM Dataset: EV_SARA 006014
       ROD: EV_SARA_006.rod
       VCID: 6BD5A6BA82B8C7D586-803E
    Address 42: Door Elect, Driver (J386)       Labels:. 4H0-959-793.clb
       Part No SW: 4G8 959 793 E    HW: 4G8 959 793 A
       Component: TSG FA        H05 0212
       Coding: 011C16200F01620002080002
       Shop #: WSC 02312 785 00200
       VCID: 428B2B1EDDB2E69D15-8016
    Address 44: Steering Assist (J500)       Labels:| 4G0-909-144.clb
       Part No SW: 4G0 909 144 L    HW: 4G0 909 144 G
       Component: RCEPS         H35 0010
       Revision: 00001000    Serial number: 0030153244
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
    Address 46: Central Conv. (J393)       Labels:. 4H0-907-064-46.clb
       Revision: 00002001    Serial number: 0158538770
       Coding: 011F1E2200B9040183A00804000100000000000000000000000000000000
       Subsystem 1 - Part No: 4G0 951 177
       Component: DWA-Sensor  H01 0010
       Subsystem 2 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HO  H05 1501
    Address 52: Door Elect, Pass. (J387)       Labels:. 4H0-959-792.clb
       Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
       Component: TSG BF        H05 0212
       Coding: 011E16204E01620002080002
       VCID: 41892412D8B4FD850C-8014
    Address 53: Parking Brake (----)       Labels: 4H0-907-801.clb
       Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
       Component: EPB-4         H03 0012
       Revision: --------    Serial number: 00000000124959
       ASAM Dataset: EV_ParkiBrake 001022
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2A5B63BE4DC21EDD3D-807E
    Address 55: Headlight Range (J431)       Labels:| 8X0-907-357.clb
       Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
       Component: ....LWR12.... H02 0013
       Serial number: 110915-0004-121
       Coding: 112196101000A300
       ASAM Dataset: EV_HeadlRegulBasic 005001
       ROD: EV_HeadlRegulBasic_AU21.rod
       VCID: 2C5765A6473600EDCF-8078
    Address 56: Radio (R)       Labels:. 4F0-035-0xx-56.clb
       Part No SW: 4G0 035 056 J    HW: 4G0 035 056
       Component: Radio U STD   H52 0133
       Revision: AB001007    Serial number: 051IY0B7533734
       Coding: 010003020100000001
       VCID: 285F99B65BCE2CCD2B-807C
    Address 5F: Information Electr. (J794)       Labels:. 4E0-035-6xx-5F.clb
       Part No SW: 4G0 035 670 P    HW: 4G0 035 670
       Component: H-BNT-EU      H47 0939
       Revision: --------    Serial number: 428I$0B7522374
       Coding: 050101000103E3EF658ACF3E00000003000001000200000100
       Subsystem 1 - Part No: 8R0 060 884 N
       Component: EUR 2011  1205
       Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
       Component: DU8 C7 SV  H42 0021
       Serial number: AUZ8ZDB1301JWQ9
       Subsystem 3 - Part No SW: 4G2 919 610 C    HW: 4G2 919 610 C
       Component: E380 BDT C7  H11 0204
       Serial number: 90349NGI00004
       Subsystem 4 - Part No: 8R0 060 961 B
       Component: CD-Database  3371
    1 Fault Found:
    03157 - Functionality limited due to Communications Disruption
                000 - -
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 6
                        Fault Frequency: 4
                        Reset counter: 115
                        Mileage: 243214 km
                        Time Indication: 0
                        Date: 2023.05.20
                        Time: 08:50:48
                 Freeze Frame:
                        Bin. Bits: 00000000 00000000
                        Bin. Bits: 00001000 00010000
                        Bin. Bits: 00000000 00010100
    Address 62: Door, Rear Left (J388)       Labels:. 4H0-959-795.clb
       Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
       Component: TSG HL        H04 0212
       Coding: 010814204001620002080002
       VCID: 44872D06C7A6E8AD27-8010
    Address 6C: Back-up Cam. (J928)       Labels:* None
       Part No SW: 4H0 907 428 A    HW: 7P6 907 441 D
       Component: TopView       H05 0120
       Revision: 11001001    Serial number: 82330JF0047511
       Coding: 0200000001000100000102000000
       Shop #: WSC 36954 001 104857
       ASAM Dataset: EV_CamerSysteTopViewAUDI 005023
       ROD: EV_CamerSysteTopViewAUDI_005_AU57.rod
       VCID: 2B5566BA423807D5C6-807E
    5 Faults Found:
    13701391 - Databus
              U1121 00 [009] - Missing Message
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 115
                        Mileage: 243214 km
                        Date: 2023.05.20
                        Time: 08:50:39
                        Voltage terminal 30: 11.3 V
                        Terminal 15 status: Terminal 15 on
    9617993 - Proximity Camera
              B145C 54 [009] - Missing Calibration / Basic Setting
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 115
                        Mileage: 243214 km
                        Date: 2023.05.20
                        Time: 08:50:40
    9616786 - Surroundings Camera Front
              B127C F0 [009] - Calibration Failed
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 115
                        Mileage: 243214 km
                        Date: 2023.05.20
                        Time: 08:50:40
    9616787 - Surroundings Camera Rear
              B127D F0 [009] - Calibration Failed
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 115
                        Mileage: 243214 km
                        Date: 2023.05.20
                        Time: 08:50:40
    10489856 - No Basic Setting
              B2010 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 115
                        Mileage: 243214 km
                        Date: 2023.05.20
                        Time: 08:50:40
    Address 72: Door, Rear Right (J389)       Labels:. 4H0-959-795.clb
       Component: TSG HR        H04 0212
    End-------------------------(Elapsed Time: 04:43)--------------------------
  5. Re: Air conditioning has stopped working 1 fault code.
    131 Post(s)
    1976 Post(s)
    Your old interface is letting you down here but these missing message codes can be seriously hard to track down even with the dealer system ODIS. U1111 shows a data exchange error in the CAN BUS system which is really specialist work to track down.
  6. Re: Air conditioning has stopped working 1 fault code.
    Feb 2013
    Uk
    38 Post(s)
    thanks crasher for getting back to me , can you recommend the latest interface ?
    That doesn’t sound good then. I’ll book it in with my independent and let you know what they come back with.
  7. Re: Air conditioning has stopped working 1 fault code.
    131 Post(s)
    1976 Post(s)
    The VCDS HEX NET is the best system I know of, the dealer system ODIS is awful to use but can help you dig deeper with these annoyingly vague missing messages codes.
  8. Re: Air conditioning has stopped working 1 fault code.
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    The system on our Golf 5 era car is kind enough to display the fault codes on its own display if you press the right buttons. Does the newer one do that?
  9. Re: Air conditioning has stopped working 1 fault code.
    Feb 2013
    Uk
    38 Post(s)
    ……the garage checked the air con , and found a tiny hole a pipe which had let the gas out over a period of time.
    all sorted now, however the errors are still there ??
  10. Re: Air conditioning has stopped working 1 fault code.
    131 Post(s)
    1976 Post(s)
    These missing messages codes are really starting to annoy me, seeing them almost daily and the only way to track them down is with ODIS in Guided Fault Finding which slow and irritating.
  1. Question Air Con not working - Fault Code U111300
    By WesleyP in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 29-09-2020, 07:20 PM
  2. Air Conditioning not working.
    By Q7quattro in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 25-12-2019, 08:48 PM
  3. P1641 Fault Code + Fans not working (to cool or for AirCon)
    By DannyBoyGolf in forum Golf MK5 - 2004 - 2009
    Last Post: 03-03-2016, 04:00 PM
  4. Question Cruise stopped working but no fault code
    By arnieboy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-12-2015, 08:47 PM
  5. Air Conditioning Still Not Working
    By biggrim in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-11-2014, 02:01 PM
