Thread: abs esp lights on
Results 1 to 10 of 12
  1. abs esp lights on
    May 2020
    Pontyclun
    1.9tdi bxe engine
    I had the car scanned and it came up with front left sensor fault.
    I fitted a genuine (from tps) sensor today and the lights are still on. i have tested the voltage at the sensor connector. 13.4v with engine running.
    A couple of weeks ago i fitted a new aftermarket bearing. this fault only came on a few days ago.
    Do i need to go and get the fault deleted since fitting the sensor?
  2. Re: abs esp lights on
    Aug 2021
    Newport
    I’d check any connectors to the sensor first that may be in the wheel arch area, sometimes hidden by the liner.
    only thing I can think is that the bearing is junk or was damaged on installation.
  3. Re: abs esp lights on
    May 2020
    Pontyclun
    The light came on a few weeks after fitting the bearing. It came on after driving through a small pothole
  4. Re: abs esp lights on
    108 Post(s)
    1816 Post(s)
    You could change everything but the pump ECU and the light will stay on unless the fault is cleared…
  5. Re: abs esp lights on
    May 2020
    Pontyclun
    i've got it booked in for reading/clearing on friday. i won't be doing anything more to it until then.
  6. Re: abs esp lights on
    May 2020
    Pontyclun
    The faults were cleared conpletely today. as the car started to drive they came straight back on again.
    The codes are as listed
    01309 j500 no signal/ no comms - intermittent
    00778 g85 no signal/comms - intermittent
    01314 engine control module no signal/comms - intermittent
    01317 j285 no signal/comms - intermittent
    01299 j533 no signal/comms - intermittent
    00474 control module for immobilizer no signal/comms - intermittent
    01130 abs operation not a plausible signal
    00283 abs wheel speed sensor, front left g47 electrical problem in circuit - intermittent
  7. Re: abs esp lights on
    108 Post(s)
    1816 Post(s)
    And these are the codes that came back or the ones there before the read?
  8. Re: abs esp lights on
    May 2020
    Pontyclun
    They were there before i changed the abs sensor and afterwards. i had it scanned twice.
  9. Re: abs esp lights on
    Aug 2021
    Newport
    You would need to hook up a suitable scanner and monitor the abs sensor feedback on the problem wheel to try and narrow it down.
    The other codes may not be relavant, I’ve seen multiple codes pop up on cars before not relating to the problem but can’t explain why exactly.
  10. Re: abs esp lights on
    108 Post(s)
    1816 Post(s)
    You have a lot more going on there than just an ABS sensor problem if they are all hard codes.
  1. Question vw polo 1.2 twist number plate lights n dashboard lights not working
    By gauchosanto in forum Polo - Derby - Lupo - Fox
    Last Post: 29-09-2017, 07:03 PM
  2. Question Coming home lights AUDI S3 - Query xenon to fog lights (information inside)
    By A6-MO in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 14-02-2013, 02:28 PM
  3. Please Help All interior lights and door lights stopped working in my Sharan 1.9 TDi (Nov 01 New Shape)
    By di4charles in forum Touran - Sharan - Caravelle
    Last Post: 09-01-2013, 01:50 AM
  4. Please Help Enabling Coming Home lights in VCDS (no auto lights fitted)
    By patomlin76 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-07-2011, 09:42 PM
  5. ABS, Glow plug, Traction control lights Flashing and no brake lights
    By bbq365 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-02-2011, 06:15 PM
