Thread: Polo driveshaft oil seals
Results 1 to 9 of 9
  1. Polo driveshaft oil seals
    Aug 2010
    oxford
    2006 Polo 1.4 BUD engine, JFM transmission, need to replace driveshaft oil seals in gearbox.
    Questions: 1)Are both seals the same size,2) Is the gearbox code an O2T, 3) Are the flanges held internally IN the gearbox by circlip on end of driveshaft-where it meets differential.?
    Any help appreciated.
  2. Re: Polo driveshaft oil seals
    1841 Post(s)
    It is a 02T series box. The right seal is 02T 409 189 K and the left is shared with the 02M series and is 02M 301 189 G, these are the new suppression numbers. The flanges are retained by M8 6mm hex head bolts 003 507 327 and these MUST be replaced. Even with new ones take care, we had one snap off in the diff before the torque was reached.
  3. Re: Polo driveshaft oil seals
    Aug 2010
    oxford
    Many thanks and for the part nos. what is the recommended torque for the M8 6mm bolt?
  4. Re: Polo driveshaft oil seals
    1841 Post(s)
    Remind me Monday
  5. Re: Polo driveshaft oil seals
    Aug 2010
    oxford
    Thanks Crasher, your Monday reminder - what torque setting for the M8 6mm hex head bolts 003 507 327 -flange retainer bolt? Cheers.
  6. Re: Polo driveshaft oil seals
    Aug 2010
    oxford
    Does anyone know what torque setting for the M8 6mm hex head bolts 003 507 327 -flange retainer bolt on O2T gearbox?
  7. Re: Polo driveshaft oil seals
    1841 Post(s)
    02T, not O2T. 25Nm.
  8. Re: Polo driveshaft oil seals
    Aug 2010
    oxford
    Brilliant ,Many many thanks for info, the O was a typo (being directly under 0) fat fingers!
  9. Re: Polo driveshaft oil seals
    1841 Post(s)
    FFS, Fat Finger Syndrome.
  1. VW Polo 9N driveshaft inner joint
    By calin1980 in forum Polo - Derby - Lupo - Fox
    Last Post: 07-08-2017, 10:32 AM
  2. Question How do I separate and reassemble Polo Mk4 (9N1) driveshaft and hub?
    By brauser rexel in forum Polo - Derby - Lupo - Fox
    Last Post: 12-03-2016, 01:42 PM
  3. Question VW Polo Mk4 1.2. 12v NSF driveshaft fitting issue
    By Phantome46 in forum Home Tech Shed
    Last Post: 12-03-2016, 01:40 PM
  4. Question Replacing driveshaft seals
    By oscarbigfeet in forum Alhambra
    Last Post: 24-09-2013, 02:25 PM
  5. Polo scrubbing driveshaft
    By dstv in forum Polo - Derby - Lupo - Fox
    Last Post: 20-07-2010, 10:43 PM
