Thread: Strange fault with rear wiper - MK2 Octavia
Results 1 to 9 of 9
  1. Strange fault with rear wiper - MK2 Octavia
    Jul 2018
    Sweden
    Wonder if any of you have any ideas....
    I have changed the motor because the arm had lost its attachment to the motor.
    I can activate the washer and motor with VCDS. Not with the lever/switch.
    No fault codes.
    The coding is correct.
    Took out the switch but couldnt see anything wrong in the board on it.
    Opened the Onboard power supply control unit when I had it in my hand - nothing obviously wrong there either.
    I have at the same time changed the ignition switch due to it having fault codes on it. Those are gone.
    Only fault code left is for the inclination sensor.
    Log-AZB599AFTER-TMBGA61Z4A2085698-200920km-124845mi.txt
  2. Re: Strange fault with rear wiper - MK2 Octavia
    1840 Post(s)
    Stupid question time but I have to ask, you are doing this with the tailgate shut?
  3. Re: Strange fault with rear wiper - MK2 Octavia
    Jul 2018
    Sweden
    Not stupid question =)
    But tailgate closed - I know VAG is fun of disengaging wiper motors when lids open.
    So unfortunatelly not that easy.
    This is really making me mad.
    I thought that it could help if the BCM was resett - but noooo. It should have been reset when battery was disengaged for about half an hour duriing the change of ignition switch.
  4. Re: Strange fault with rear wiper - MK2 Octavia
    1840 Post(s)
    It is puzzling that it will work in output tests but not from the switch, have you viewed the switch inputs in the steering column controller?
  5. Re: Strange fault with rear wiper - MK2 Octavia
    Jul 2018
    Sweden
    Sorry - forgot to mention that - yes and they too show up correct in Measuring Blocks!
  6. Re: Strange fault with rear wiper - MK2 Octavia
    Jul 2018
    Sweden
  7. Re: Strange fault with rear wiper - MK2 Octavia
    1840 Post(s)
    I can't remember if the BCM shows it is receiving that signal, have you have a look?
  8. Re: Strange fault with rear wiper - MK2 Octavia
    Jul 2018
    Sweden
    Would that be in 09 - Central Electric - group?
    If I remember correct I couldnt see any measuring blocks for wipers, in 09. Only doors and lighs and such.
  9. Re: Strange fault with rear wiper - MK2 Octavia
    Jul 2018
    Sweden
    Alright - she has been by.
    In 09 - measuring blocks - I can ONLY see front wipers activated. No rear. Searched "Wiper" in Advanced Measuring Blocks. Only the windscreen wipers appeared.
    Further - I checked through all blocks in the Long Coding. Finally got to rear wipers - and all that could be ticked - are ticked.
  1. Avant Rear Wiper - Strange behaviour
    By Nomarky in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 05-02-2021, 04:55 PM
  2. Strange rear wiper behavior - Golf Mk 4 hatch - is this normal?
    By Last Triumph in forum Golf MK4 - 1999 - 2004
    Last Post: 22-09-2014, 02:14 PM
  3. Question Octavia Mk 1 - Rear wiper arm
    By Jase89 in forum Octavia
    Last Post: 28-08-2014, 01:03 PM
  4. Octavia Rear Wiper Fault, Help Please!!!!!!
    By Lofty79 in forum Octavia
    Last Post: 03-11-2013, 12:00 PM
  5. Octavia estate rear wiper
    By david muir in forum Octavia
    Last Post: 28-11-2008, 12:03 AM
