Thread: Loud Ticking Noise/Loud Engine
Page 1 of 3 123 LastLast
Results 1 to 10 of 28
  1. Loud Ticking Noise/Loud Engine
    Sep 2019
    Glasgow
    Hi. I’m looking to see if anybody knows what my problem could be or have came across the same issue.
    Bought a 2018 Passat 2.0TDI 150 DSG number of months back. I travelled long distance to buy the car and when I started it and first drove it was rather noisy but I put that down to perhaps cold engine. Once purchased the car was on motorway coming home car drove well. I use the car for work (Taxi) so once I started doing so I noticed once the engine heats up there is a loud ticking noise (at idle) as if it comes from the timing belt area and is particularly loud when going through the likes McDonalds drive through where the wall reflects the sound. When cold it’s nowhere as bad but I do have the cricket sound which is more common when cold only. Also at times I feel there’s a slight sluggishness at times like it’s not so responsive.. The car seems far smoother, quieter and faster when it does its DPF regen and even the ticking noise sounds quieter at idle too. No fault codes or anything. Car is still under warranty but I get the feeling I will be told the car is fine. Have came from the B7 2.0 140 with very high mileage and you would think that was the newer sounding car much better sounding. Not impressed at all with this new car.
  2. Re: Loud Ticking Noise/Loud Engine
    Mar 2021
    Ripon
    7 Post(s)
    Sounds very similar to mine. If in doubt get it checked out. Sadly, it's not the last word in refinement and does sound still sound like a tractor when listening to the engine from outside the car.
  3. Re: Loud Ticking Noise/Loud Engine
    2007 Post(s)
    Certain versions of these engines have common issues with the cam drive system, especially those with VVT. I can tell you if yours is one of the afflicted [sic] if you PM me the reg. A fellow mechanic once described it to me as sounding like a "skeleton masturbating in a biscuit tin"
  4. Re: Loud Ticking Noise/Loud Engine
    2007 Post(s)
    It doesn’t have the VVT system and it has the post 16-04-18 (yours was built 18-10-2018) camshaft module so it SHOULD not have that issue that I have seen with a LOT of VAG taxi vehicle’s.
  5. Re: Loud Ticking Noise/Loud Engine
    Sep 2019
    Glasgow
    Thanks for your help. It could well be scratch the head issue and nothing is found. But more I drive the car the more it frustrates me. You can floor it on one occasion car is rapid, smooth and what I would say a normal noise. Then floor it on another occasion it feels sluggish and has the tractor noise symptoms aswell as a horrible drone noise in background. Found this clip of a Skoda Superb which is the same noise as my own car.
    Superb III engine noise - 2.0 TDI 110 kw - YouTube
  6. Re: Loud Ticking Noise/Loud Engine
    2007 Post(s)
    You will have to either let it develop or have a VAG group experienced ear listen to it.
  7. Re: Loud Ticking Noise/Loud Engine
    Mar 2021
    Ripon
    7 Post(s)
    I can relate to the above. In June, I changed the oil and replaced air, oil, pollen and fuel filter on ours and since it has run quieter. I used VW quantum oil and thought it was this that made the difference. Still noisier than a lot of modern diesels though!
  8. Re: Loud Ticking Noise/Loud Engine
    Sep 2019
    Glasgow
    Defo a lot quieter and more like my older Euro 5 engine. But outside I would say the Euro 5 2.0tdi was a tad quieter.. Been told Euro 5 much better engine. Plenty of guys in the Taxi Trade with both 1.6 and 2.0 Euro 5s have gone over the 300k miles mark with there cars. Not sure the Euro 6 engines will get that. Certainly don’t know anybody yet with major high mileage on Euro 6 models. Will wait and see.
  9. Re: Loud Ticking Noise/Loud Engine
    Sep 2019
    Glasgow
    Shouldn’t have said anything. The noise has suddenly returned but more of a concern is a chattering noise has now occurred. Think this is DMF noise. Car was sluggish and noisy for a considerable bit this morning (it’s like lack of turbo spool) . When I sat with engine off then turned back on the car would be fast and quiet. Thought I had seen the back of these problems.
  10. Re: Loud Ticking Noise/Loud Engine
    Mar 2021
    Ripon
    7 Post(s)
    I would recommend checking the car for fault codes. I am assuming you are out of warranty. Did you buy the car from a dealer or at auction/privately? If there is a serious fault and you bought the car from a dealer, less than 6 months ago, then you may well be covered by the 2015 sale of goods act.
  1. Loud ticking noise problem 3.0 tdi - throttle body valve??
    By filip_a in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 02-09-2016, 04:36 PM
  2. loud engine noise on start up.
    By stuspla in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 25-05-2012, 01:39 PM
  3. Please Help Loud ticking noise from 2.0TDI
    By BigWak in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-02-2010, 02:26 PM
  4. 2.0 tdi no power and a loud ticking noise
    By denlinco in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 29-04-2009, 10:35 PM
  5. TDI 115 loud ticking noise
    By mwmackenzie in forum Bora - 1998 - 2005
    Last Post: 13-04-2009, 12:24 AM
