Thread: audi a4 2010 none starter possible timing no fault codes
Results 1 to 10 of 13
  1. audi a4 2010 none starter possible timing no fault codes
    where do i start lol
    Audi a4 2010 2.0 tfsi cdnc engine code
    car had a slight misfire scanned the car cam sensor so i thought i would change the cam sensor as well as the crank sensor and spark plugs that's where my problems started on trying to start the engine it sounds like a diesel runs for a few seconds then cuts out changed that which i did know the car wont start so checked the following
    checked voltage to crank sensor and cam sensor and coil packs
    checked chain visually it looks good there's a bit of movement till you crank the engine then it tightens up
    which i understand is correct checked the timing with vcds photo added
    the car has a spark on all 4 coil packs I've changed them between cylinders and all firing
    I've pulled the plugs cranked the engine you can see the injectors firing fuel into the cylinders
    done a compression test 195 psi on all 4 cylinders
    pulled the plugs out plus bank one o2 sensor and there carboned up straight away there are no fault codes mechanic cant look at the car while next week as anyone any idea where i can look next
    I've disconnected the fuel line to the fuel rail there's fuel there I've took the plugs out and cranked it you can see them firing away if i start the engine with the plugs in it sounds like its running on two cylinders then cuts out if a disconnect the coil packs it spins over like it should do I've changed the crank sensor for another replacement to see if it helps it didn't
    Sent from Outlook Email App for Android
  2. Re: audi a4 2010 none starter possible timing no fault codes
    1837 Post(s)
    I assume no fault codes? Running the coil packs without a very good ground on the plugs can damage them so they will not ionise a spark under compression but they will at atmospheric pressure which can be quite deceiving. Off course the worry is cam timing so you should check this.
  3. Re: audi a4 2010 none starter possible timing no fault codes
  4. Re: audi a4 2010 none starter possible timing no fault codes
  5. Re: audi a4 2010 none starter possible timing no fault codes
    ive just added videos of the car starting with coil packs connected sounds like a diesel
    the next video is with the coil packs disconnected sounds to be normal when turning over
  6. Re: audi a4 2010 none starter possible timing no fault codes
    ive just added some videos of the car crasher do you think the coil packs could be damaged know
    thanks paul
  7. Re: audi a4 2010 none starter possible timing no fault codes
    1837 Post(s)
    I can't hear the video, ever since Windows updated my sound card doesn't work. If you have run the coil packs out of the head it is likely they have suffered so I would fit four new Bosch coils to start with and see what happens.
  8. Re: audi a4 2010 none starter possible timing no fault codes
    Ive ordered 4 bosch coil packs justing waiting for them to arrive and then will try that to be fair anything I do will save me in the long run if I need to put with a audi specialist they would only do the same and charge for the time will keep you posted crasher
  9. Re: audi a4 2010 none starter possible timing no fault codes
    1837 Post(s)
    If you have ordered them with Aut0d0c I hope you don’t mind waiting.
  10. Re: audi a4 2010 none starter possible timing no fault codes
    No crasher should be here for Saturday 🤞
  1. Question Audi a4 2.0 tdi b7 2006 cranking, none starter, no fault codes on vcds ?
    By Robert Ravenscroft in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 16-02-2017, 10:11 PM
  2. AUDI A4 B6 - Various Fault Codes
    By jakroyd11733 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-10-2016, 09:16 PM
  3. Audi A3 - 8P - 2010 - 1.6 TDI (CR) - CAYC - Timing Marks
    By DCEd in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 15-04-2015, 10:12 PM
  4. AUDI RS4 with Starter Interlock Signal fault
    By anth hall in forum VCDS - Help Requests
    Last Post: 02-07-2013, 08:05 PM
  5. Fault with Audi Q5 2010
    By Schuzzy in forum Q5
    Last Post: 25-02-2012, 11:14 AM
