Thread: SQ7 Tdi turbo issue
Page 5 of 5 FirstFirst ... 345
Results 41 to 45 of 45
  1. Re: SQ7 Tdi turbo issue
    #41
    May 2016
    Birmingham UK
    Quote Originally Posted by filipsladecka View Post
    under the the 1st big turbo in front and also end of egr cooler pipe...it is going to inlet metal piece in front also. it is quite logic when you put out turbo...and also when you delete egr cooler you need to delet also one thottle vavle...car had no power if you dont floor it....that what my ecu software guy said...
    hi when your software guy disabled the throttle valve did he tell you to disconnect the plug from the valve too?
  2. Re: SQ7 Tdi turbo issue
    #42
    Mar 2025
    Wolves, UK
    Hi, I had a similar issue and posted in a neighbouring forum here. Can't understand how my bhp is higher than stock but can't get 0-60 nearly as quick as stock. There is a suggestion on there already, but I think it's been mentioned here. Just wondering if there has been any success since the last posts??
  3. Re: SQ7 Tdi turbo issue
    #43
    Mar 2025
    Switzerland
    Hello guys. I had the same problem. Clean sensor G691 and his connecting tube with brake cleaner and everything will be ok. The sensor is located at the left of the active turbo on a tube going down and under the turbo.
  4. Re: SQ7 Tdi turbo issue
    #44
    Mar 2025
    Wolves, UK
    Quote Originally Posted by Admaz View Post
    You don't happen to have a diagram/photo of the location and the sensor do you? Looks a tight squeeze in the SQ7 engine, is it easy to access. Did a search for the sensor and it didn't bring up much. There were some articles about replacing the throttle sensor on the pedal though.
  5. Re: SQ7 Tdi turbo issue
    #45
    Mar 2025
    Switzerland
    Quote Originally Posted by scottiecb19 View Post
    Here you will see images:
    https://www.motor-talk.de/forum/sq7-...44.html?page=2
  1. Turbo issue
    By sykums in forum 2.0T, TSI and TFSI - Engine
    Last Post: 11-08-2018, 05:39 PM
  2. Turbo issue
    By magor226 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-06-2017, 12:21 PM
  3. Question Possible Turbo Issue?
    By Enad in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 27-12-2016, 11:44 AM
  4. Turbo issue
    By khalidsaid94 in forum 1.8T - Engine
    Last Post: 29-12-2013, 01:20 AM
  5. Please Help turbo issue?
    By emleymonkey in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-07-2012, 11:29 PM
