Thread: Engine Fault, Parking Brake and ABS Light all on at the same time
  1. Engine Fault, Parking Brake and ABS Light all on at the same time
    Jul 2021
    Lincoln, Lincolnshire
    Just wondering if anyone can help?
    Recently on my 2006 Passat i was driving and my engine lost power for around 2 seconds before showing an Engine Fault, ABS and Parking Brake light simultaneously.
    This has now become an intermittent fault where the lights will disappear for an hour or so but then appear again with the same small drop in engine power.
    Sadly I don't have a code reader to diagnose the issue.
    The car still seems to run fine. The only noticeable difference is that when these lights are on i cannot engage my Cruise Control.
    any help would be greatly appreciated
  2. Re: Engine Fault, Parking Brake and ABS Light all on at the same time
    1840 Post(s)
    You must start with a proper code read with VAG specific equipment, save and clear the codes and then run the car again until the fault re-occurs and then another scan and compare the results of the two.
  1. Replies: 0
    Last Post: 17-05-2018, 03:48 PM
  2. 3rd brake light not working , no revs , engine mangement on from time to time
    By icemano3 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 09-10-2013, 10:01 PM
  3. Please Help Parking brake fault+ESP light on - can not start the engine!
    By valjo in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-02-2013, 01:57 PM
  4. parking brake malfunction, abs, power steering, engine light
    By frankiefee in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 17-01-2013, 11:50 PM
  5. Question Engine warning and parking brake warning lights on at same time
    By ajh in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-05-2010, 05:33 PM
