Thread: Air con not working properly ??
  1. Air con not working properly ??
    Nov 2008
    Rochdale
    Good evening everyone, just looking for a tad of help please, I have a 3.0 tdi A5 and the air con doesn't always work correctly, had it scanned on VCDS and the following faults have been noticed.... Address 08: Auto HVAC Labels: 8Kx-820-043-3Z.clbControl Module Part Number: 8K2 820 043 T HW: 8K2 820 043 T
    Component and/or Version: KLIMA 3 ZONEN H04 0121
    Software Coding: 3624028000
    Work Shop Code: WSC 06325 000 00000
    VCID: 3A7F648AB558E25BCD-806E
    3 Faults Found:
    01231 - Right Footwell Vent Temperature Sensor (G262)
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 01101010
    Fault Priority: 3
    Fault Frequency: 7
    Reset counter: 168
    Mileage: 223985 km
    Time Indication: 0
    Date: 2021.07.26
    Time: 16:27:59
    Freeze Frame:
    Temperature: 26.0°C
    Speed: 0.0 km/h
    Voltage: 12.00 V
    01230 - Left Footwell Vent Temperature Sensor (G261)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 6
    Reset counter: 168
    Mileage: 223985 km
    Time Indication: 0
    Date: 2021.07.26
    Time: 16:28:00
    Freeze Frame:
    Temperature: 26.0°C
    Speed: 0.0 km/h
    Voltage: 11.90 V
    00818 - Sensor for Evaporator Outlet Temperature (G263)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 168
    Mileage: 224001 km
    Time Indication: 0
    Date: 2021.07.26
    Time: 16:57:55
    Freeze Frame:
    Temperature: 26.0°C
    Absolute Pres.: 7.8 bar
    Voltage: 14.30 V
    Current: 0.000 A
    Address 08: DTCs cleared
    I believe the G263 is the pressure sensor on the air con radiator with an electrical connector atop, this was replaced a couple of years ago ( Genuine Audi part and condensor as well ), the air con does work but not as Audi would have wanted it too, it runs for a few mins and cuts off, then restarts after a while ( particularly in auto mode )would the footwell vent sensors be anything to do with the G263 sensor.
    The system is full of gas and works a bit sporadically, just hoping that someone with a bit of knowledge can help me out.
    Kind Regards
    Darren
  2. Re: Air con not working properly ??
    Nov 2008
    Rochdale
    Sorry Schoolboy error !!!!!!!!! Its been a while since I last posted, I will update accordingly
  1. Question Air Con not working properly
    By Mani23 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 26-10-2019, 06:09 PM
  2. Air con not working properly
    By shabazmo in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 29-05-2019, 11:03 PM
  3. Heater Not working Properly
    By jakroyd11733 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-12-2016, 09:09 PM
  4. Question A6 SE TDI Estate MMI not working properly
    By dominic2016 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 14-01-2016, 10:51 PM
  5. Question Heater isn't working properly
    By hardpack in forum Golf MK4 - 1999 - 2004
    Last Post: 04-10-2010, 06:43 AM
