Thread: Engine starting issue
  1. Engine starting issue
    Jun 2011
    chester
    Hi, firstly thanks in advance.
    I have had a problem with starting my car for a while but only intermittent like once a week. When starting engine, it turns but fails to start and Glow plug light comes on, also sometimes the engine turns a few times before starting. But on second attempt always started.
    However, recently on holiday it wouldn't start, tried about 15 times, then waited for 5 mins then started. Following day I went to Euro car parts and replaced all Glow plugs. Car was fine for 2 days and then back to dodgy starting again but not like the time it took 15 goes.
    Battery was changed a year ago so can't be that.
    I ran Carista and there were other minor faults like ABS etc but all fine after clearing. There was one code which is 04096 which I'm not sure about
    Any ideas what could be causing this??
    Any help will be appreciated.
  2. Re: Engine starting issue
    1836 Post(s)
    You need a proper code read and which year/engine?
  3. Re: Engine starting issue
    Jun 2011
    chester
    It's a 2012 2.0 diesel engine.
  1. Please Help 2011 Passat 2.0 Diesel not starting - 01314 - Engine Control Module issue
    By Pandaman5005 in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 10-04-2020, 02:17 PM
  2. Please Help Engine Cutting out while running, slight issue starting up
    By hatton101 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-02-2016, 10:58 PM
  3. Starting Issue
    By hippy999 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-04-2011, 08:14 AM
  4. Please Help Starting issue A4 1.9 TDI 90
    By Connor_Scotland in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-12-2010, 12:22 AM
  5. A4 AYM engine starting issue
    By lojiuk in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-11-2010, 08:10 AM
